2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bfrk/epics-base:address-modifiers into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mp+381628 at code.launchpad.net
Date: Thu, 16 Apr 2020 19:47:17 -0000
@Andrew I have addressed most of the issues you raised and made the address modifier API polymorphic.
The parsing is not yet encapsulated. There is a trade-off here: we use the same syntax as a short-cut for filters. Not sure what to do here; perhaps create a separate module just for this parser. I'll have to experiment to see if that results in a better structure.
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/381628
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:address-modifiers into epics-base:7.0.
[Merge] ~bfrk/epics-base:address-modifiers into epics-base:7.0 Ben Franksen via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:CleanupWhitespace into epics-base:7.0 mdavidsaver via Core-talk
Next: Build failed: EPICS Base base-7.0-584 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~bfrk/epics-base:address-modifiers into epics-base:7.0 Ben Franksen via Core-talk
Next: Re: [Merge] ~bfrk/epics-base:address-modifiers into epics-base:7.0 Ben Franksen via Core-talk
ANJ, 16 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
