2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: AW: Problem compiling EPICS 7 commit 85d1982 when INSTALL_LOCATION is set
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>, "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Fri, 17 Apr 2020 14:02:10 +0000
I think the problem is  a missing space in the search path:
@INC contains: /afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-reformat/src/tools/../../lib/perl ...
I guess that should be: /afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-reformat/src/tools/ ../../lib/perl ...
-----Ursprüngliche Nachricht-----
Von: Core-talk <core-talk-bounces at aps.anl.gov> Im Auftrag von Zimoch Dirk (PSI) via Core-talk
Gesendet: Freitag, 17. April 2020 15:22
An: 'core-talk at aps.anl.gov' <core-talk at aps.anl.gov>
Betreff: AW: Problem compiling EPICS 7 commit 85d1982 when INSTALL_LOCATION is set
Neither branch 3.15 commit 841effe (HEAD) nor commit 45cf2ea (merged into 7.0)  nor branch 7.0 commit ad44c7a5 9before merge) has this problem. It appears only with the last merge.
Dirk
Gesendet: Freitag, 17. April 2020 14:56
Betreff: Problem compiling EPICS 7 commit 85d1982 when INSTALL_LOCATION is set
$make EPICS_HOST_ARCH=linux-x86_64 INSTALL_LOCATION=/home/zimoch/epics7
Installing html /home/zimoch/epics7/html/./style.css
mkdir /home/zimoch/epics7/html
mkdir /home/zimoch/epics7/html/.
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
Can't locate EPICS/PodHtml.pm in @INC (@INC contains: /afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-reformat/src/tools/../../lib/perl /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at ../../../src/tools/podToHtml.pl line 18.
BEGIN failed--compilation aborted at ../../../src/tools/podToHtml.pl line 18.
make[3]: *** [../O.Common/EPICS/Getopts.html] Error 2
make[3]: Leaving directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-reformat/src/tools/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-reformat/src/tools'
make[1]: *** [tools.install] Error 2
make[1]: Leaving directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0-reformat/src'
make: *** [src.install] Error 2
A colleague has reported the same problem on Windows.
No problem when INSTALL_LOCATION is not set.
Dirk
AW: Problem compiling EPICS 7 commit 85d1982 when INSTALL_LOCATION is set Zimoch Dirk (PSI) via Core-talk
Prev: AW: Problem compiling EPICS 7 commit 85d1982 when INSTALL_LOCATION is set Zimoch Dirk (PSI) via Core-talk
Next: AW: Problem compiling EPICS 7 commit 85d1982 when INSTALL_LOCATION is set Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 17 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
