2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: tapfiles double-colon rule
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Ralph Lange <Ralph.Lange at gmx.de>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Mon, 20 Apr 2020 17:40:36 +0000
Hi Ralph,
You committed this to the 3.15 branch last week:
commit cbf917e8332d620b6a2f60ea9822d1f84467ef28
Author: Ralph Lange <ralph.lange at gmx.de>
Date:   Thu Apr 16 12:04:16 2020 +0200
    Improve automated testing rules to allow other test frameworks
    - make runtests a double-colon rule, so that other test frameworks
      can add their own recipes independently
    - only define runtests:: $TESTSCRIPTS rule when there are TESTSCRIPTS
      (to avoid having it run every time when no TESTSCRIPTS are defined)
    - $(strip $TAPFILES) inside ifneq to fix trouble when TAPFILES=' '
I would like to undo the double-colon change, it is never actually necessary and double-colon rules can cause problems, although I’m not exactly sure what specific issues caused Janet to very deliberately change the clean rule back from a double-colon to a single-colon rule again (it was single-colon in earlier versions).
You can add additional recipes for the runtests target without them clashing with the existing one by adding intermediate targets, e.g.:
runtests: run-gtests
run-gtests: ...dependencies...
...commands...
With that modification I don’t think your other changes are required either, although I could be wrong. If you want I could add a similar intermediary for the tap-tests.
BTW take a look at the new pre-make and test-results recipes I’m considering adding to RULES_TOP in https://github.com/epics-base/epics-base/compare/3.15...anjohnson:appveyor?expand=1. pre-make may be a bad name, it gets run by RULES_DIRS before any recursion into a subdirectory; I needed it to clean out the new test summary file which the new test-results recipe displays and uses to mark test failures as an error. The exact behavior of the testFailures.pl script could be changed, but the idea is to collect all the test failures and have the test-results target print them out at the end of the build rather than bury them higher up. I realized these were needed after my last commit to the 3.15 branch which stopped the test-results target from ever failing; I wanted it to display all the results before test-results stopped, and for some reason ‘make -k’ isn’t doing that properly on the 7.0 builds.
Comments and suggestions on that welcome. For some reason Appveyor was failing most of my builds of this over the weekend but they’re passing now, I don’t think the two commits I made should have changed anything though.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: tapfiles double-colon rule Ralph Lange via Core-talk
Prev: Re: Problem compiling EPICS 7 commit 85d1982 when INSTALL_LOCATION is set Johnson, Andrew N. via Core-talk
Next: Re: tapfiles double-colon rule Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Build failed: EPICS Base base-7.0-591 AppVeyor via Core-talk
ANJ, 20 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
