2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1873406] Re: EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 23 Apr 2020 07:51:56 -0000
Since the current behavior is not technically wrong, and your suggestion
would introduce an IMHO worse wrong setting, I propose to leave things
as they are for this upcoming release, and discuss the intentions and
workings of the EpicsHostArch script more broadly.
I believe a user tool should focus on user friendliness and try to come
up with the best setting for the EPICS build in the context it is being
called from.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1873406
Title:
  Windows
Status in EPICS Base:
  New
Status in EPICS Base 3.15 series:
  New
Status in EPICS Base 7.0 series:
  New
Bug description:
  On MSYS2/MinGW installations, the EpicsHostArch script does not
  recognize the host platform correctly.
  64bit:
  $ ./startup/EpicsHostArch
  lib/perl/EpicsHostArch.pl: Architecture 'x86_64-msys-thread-multi' not recognized
  32bit:
  Which is not surprising, as the underlying MSYS2 subsystem is the
  same, and the difference is in the environment settings that point to
  the appropriate toolchain.
  64bit:
  $ echo $PATH
  /mingw64/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
  $ printenv | grep MSYSTEM
  MSYSTEM_CARCH=x86_64
  MSYSTEM_CHOST=x86_64-w64-mingw32
  MSYSTEM_PREFIX=/mingw64
  MSYSTEM=MINGW64
  32bit:
  $ echo $PATH
  /mingw32/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
  MSYSTEM_CARCH=i686
  MSYSTEM_CHOST=i686-w64-mingw32
  MSYSTEM_PREFIX=/mingw32
  MSYSTEM=MINGW32
  NB: I am impressed by the clarity and simplicity of MSYS2 / MinGW
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1873406/+subscriptions
Re: [Bug 1873406] Re: EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows Ben Franksen via Core-talk
[Bug 1873406] [NEW] EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows Ralph Lange via Core-talk
Prev: [Bug 1873406] Re: EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows Ralph Lange via Core-talk
Next: Confusion at epics time Heinz Junkes via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: Re: [Bug 1873406] Re: EpicsHostArch script does not detect recent MSYS2/MinGW setups on Windows Ben Franksen via Core-talk
ANJ, 23 Apr 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
