2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1829770] Re: event record device support broken with constant INP
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 15 May 2020 15:45:43 -0000
** Changed in: epics-base/3.15
    Milestone: None => 3.15.8
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1829770
Title:
Status in EPICS Base:
  Invalid
Status in EPICS Base 3.15 series:
  Fix Committed
Status in EPICS Base 7.0 series:
  Invalid
Bug description:
  Eric Norum reported:
  ------------------ 8< ---------------------
  record(event, "$(P)$(R)reconn_") {
      field(DTYP, "Soft Channel")
      field(INP,  "55")
    field(TPRO, "1")
  record(fanout, "$(P)$(R)reconnWFR_") {
      field(SCAN, "Event")
      field(EVNT, "55")
    field(TPRO, "1")
  When the “reconn_” record is processed, niether ”reconnWFR_” nor any
  other record with that SCAN setup gets triggered. It’s not enough to
  set INP=55 in the .db file, I must explicitly set VAL for it to work.
  The init_record() routine in devEventSoft.c (Base-3.15 branch) doesn't
  look right, I think it's missing a call to eventNameToHandle().
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1829770/+subscriptions
Prev: Build completed: EPICS Base base-3.15-610 AppVeyor via Core-talk
Next: [Bug 1829919] Re: IOC segfaults when calling dbLoadRecords after iocInit Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1829770] Re: event record device support broken with constant INP Gabriel Fedel via Core-talk
Next: [Bug 1829770] Re: event record device support broken with constant INP Andrew Johnson via Core-talk
ANJ, 15 May 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
