2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: AW: make runtests fails with "touch: missing file operand"
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>, Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Fri, 5 Jun 2020 08:09:57 +0000
I can confirm that the problem only happens when no submodule is checked out. (I had that to work on the zero-size array topic.)
The patch fixes the problem.
BTW: Two ways to switch off git colors:
git diff –color=never
git diff | cat  (assuming the default is –color=auto)
Von: Johnson, Andrew N. <anj at anl.gov>
Gesendet: Mittwoch, 3. Juni 2020 20:51
An: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>; EPICS core-talk <core-talk at aps.anl.gov>
Betreff: Re: make runtests fails with "touch: missing file operand"
On Jun 3, 2020, at 1:06 PM, Michael Davidsaver <mdavidsaver at gmail.com> wrote:
git apply /tmp/dirk.diff
error: patch failed: configure/RULES_MODULES:50
error: configure/RULES_MODULES: patch does not apply
Please send patches as attachments.
(or use git-send-email if you really must)
I don’t think I could use git-send-email from my Mac even if I knew how. Apple’s Terminal application copies as rich-text, so the colors that git diff shows are almost certainly why your git-apply failed.
- Andrew
Complexity comes for free, simplicity you have to work for.
make runtests fails with "touch: missing file operand" Zimoch Dirk (PSI) via Core-talk
Re: make runtests fails with "touch: missing file operand" Johnson, Andrew N. via Core-talk
Re: make runtests fails with "touch: missing file operand" Michael Davidsaver via Core-talk
Prev: AW: EPICS 7 and VxWorks 6.9 for PPC604? Zimoch Dirk (PSI) via Core-talk
Next: AW: EPICS 7 and VxWorks 6.9 for PPC604? Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: make runtests fails with "touch: missing file operand" Johnson, Andrew N. via Core-talk
Next: Build failed: epics-base base-vfield-514 AppVeyor via Core-talk
ANJ, 05 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
