2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1881563] Re: Empty arrays have undefined behavior
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 05 Jun 2020 18:36:17 -0000
What I see so far on your fix_zero_size_arrays branch looks
straightforward and reasonable.  In short, something which could be
merged by itself soon.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1881563
Title:
Status in EPICS Base:
  In Progress
Status in EPICS Base 7.0 series:
  In Progress
Bug description:
  The behavior of arrays with 0 elements is inconsistent and seemingly
  undefined. I made the fllowing observations:
  1. Reading empty arrays with caget shows NELM values, all 0 except for
  the first which sometimes contains strange not-quite-random numbers
  (see bug report 1242919). I have observed values 0, 2.122e-314,
  2.50321e-308, 22, 18, 2.02038e-39, 1441792, 1179648, 3.05948e-308,
  also depending on the -d option (DBR type) of caget.
  2. Reading empty arrays with camonitor shows no values.
  3. A scalar input record reading INP or scalar output record reading
  DOL (with OMSL closed_loop) from an empty array (aai, aao or waveform)
  reliably reads the value 0 (tested with ai, bi, mbbi, mbbiDirect,
  longin, stringin, ao, bo, mbbo, mboDirect, longout, stringout). This
  is true for DB links as well as for CA, CP and CPP links.
  4. An array record (aai, waveform) reading from an empty array does
  not change its current value. It does not change NORD, it does not
  clear the arrays elements, it does not show an alarm.
  5. Writing 0 elements to an array with caput -a fails whith "Invalid
  element count requested".
  My opinion on this behavior is as follows:
  1. Reading arrays with caget should return NORD elements, not NELM
  elements. But if we put this side, the additional elements should all
  be set to 0. For empty arrays, this includes the the first one (index
  0).
  2. This is correct behavior.
  3. This is consistent but questionable. Converting an empy array to a
  scalar should fail as there is no value to convert. But that might
  break existing dbs. In that case this behavior should be documented.
  (Or is it?)
  4. This behavior is buggy. The receiving record should update its NORD
  to 0.
  5. It should be possible to write an empty array.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1881563/+subscriptions
[Bug 1881563] [NEW] empty arrays have undefined bahavior Dirk Zimoch via Core-talk
Prev: Build failed: epics-base base-ci-core-dumper-525 AppVeyor via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-24 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: [Bug 1881563] Re: Empty arrays have undefined behavior Andrew Johnson via Core-talk
Next: [Bug 1881563] Re: Empty arrays have undefined behavior Dirk Zimoch via Core-talk
ANJ, 08 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
