2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1887981] [NEW] json parser should accept hex numbers
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 17 Jul 2020 14:58:24 -0000
Public bug reported:
Hex integers are supported in JSON5.
It would be nice if I could use them in EPICS e.g.
field (INP, [0x40,0x42])
** Affects: epics-base
     Importance: Undecided
         Status: New
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1887981
Title:
Status in EPICS Base:
  New
Bug description:
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1887981/+subscriptions
[Bug 1887981] Re: json parser should accept hex numbers Andrew Johnson via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:fix_zero_size_arrays into epics-base:7.0 Dirk Zimoch via Core-talk
Next: [Bug 1887981] Re: json parser should accept hex numbers Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: AW: EPICS linker problem Michael Davidsaver via Core-talk
ANJ, 17 Jul 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
