2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Minor issue with base 7.0.4.1
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Wed, 26 Aug 2020 22:42:44 +0000
I just updated base to 7.0.4.1
When I run “make –sj clean uninstall” on Centos 7 I get the following error message:
corvette:local/epics-devel/base-7.0.4>make -sj clean uninstall
Can't open perl script "/usr/local/epics-devel/base-7.0.4/bin/linux-x86_64/fullPathName.pl": No such file or directory
I think the command worked OK, but the error message is disconcerting.
Re: Minor issue with base 7.0.4.1 Johnson, Andrew N. via Core-talk
Prev: Re: Question from the RTEMS corner J. Lewis Muir via Core-talk
Next: Opinions please, what should this database do Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: Question from the RTEMS corner Chris Johns via Core-talk
Next: Re: Minor issue with base 7.0.4.1 Johnson, Andrew N. via Core-talk
ANJ, 27 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
