2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: No access to epics-base.git for push
From: junkes via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 28 Aug 2020 16:14:09 +0200
Apparently I have no right to upload my RTEMS5 stuff to epics-base.
[h1@earth QtC-epics-base (7.0 *)]$ git push
Username for 'https://github.com': hjunkes
Password for 'https://hjunkes at github.com':
remote: Permission to epics-base/epics-base.git denied to hjunkes.
fatal: unable to access 'https://github.com/epics-base/epics-base.git/': The requested URL returned error: 403
What is the best way for me to continue here now?
heinz
Changes to be committed:
  (use "git reset HEAD <file>..." to unstage)
        modified:   configure/CONFIG_COMMON
        modified:   configure/os/CONFIG.Common.RTEMS
        new file:   configure/os/CONFIG.Common.RTEMS-beagleboneblack
        modified:   configure/os/CONFIG.Common.RTEMS-beatnik
        modified:   configure/os/CONFIG.Common.RTEMS-pc386
        new file:   configure/os/CONFIG.Common.RTEMS-qoriq_e500
        new file:   configure/os/CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
new file: configure/os/CONFIG.Common.RTEMS-xilinx_zynq_zedboard
        modified:   configure/os/CONFIG.darwin-x86.Common
        modified:   configure/os/CONFIG_SITE.Common.RTEMS
        modified:   documentation/RELEASE_NOTES.md
        modified:   modules/libcom/RTEMS/Makefile
        modified:   modules/libcom/RTEMS/epicsMemFs.c
        modified:   modules/libcom/RTEMS/epicsMemFs.h
        new file:   modules/libcom/RTEMS/epicsNtp.c
        new file:   modules/libcom/RTEMS/epicsNtp.h
        modified:   modules/libcom/RTEMS/epicsRtemsInitHookPost.c
        modified:   modules/libcom/RTEMS/epicsRtemsInitHookPre.c
        modified:   modules/libcom/RTEMS/epicsRtemsInitHooks.h
        new file:   modules/libcom/RTEMS/kernel/epicsRtemsInitHookPost.c
        new file:   modules/libcom/RTEMS/kernel/epicsRtemsInitHookPre.c
        new file:   modules/libcom/RTEMS/kernel/epicsRtemsInitHooks.h
renamed: modules/libcom/RTEMS/rtems_config.c -> modules/libcom/RTEMS/kernel/rtems_config.c renamed: modules/libcom/RTEMS/rtems_init.c -> modules/libcom/RTEMS/kernel/rtems_init.c renamed: modules/libcom/RTEMS/rtems_netconfig.c -> modules/libcom/RTEMS/kernel/rtems_netconfig.c
        new file:   modules/libcom/RTEMS/kernel/setBootConfigFromNVRAM.c
        modified:   modules/libcom/RTEMS/ne2kpci.c
        new file:   modules/libcom/RTEMS/posix/epicsRtemsInitHookPost.c
        new file:   modules/libcom/RTEMS/posix/epicsRtemsInitHookPre.c
        new file:   modules/libcom/RTEMS/posix/epicsRtemsInitHooks.h
        new file:   modules/libcom/RTEMS/posix/libbsd_netconfig.c
        new file:   modules/libcom/RTEMS/posix/libbsd_netconfig.h
        new file:   modules/libcom/RTEMS/posix/rtems_config.c
        new file:   modules/libcom/RTEMS/posix/rtems_init.c
        new file:   modules/libcom/RTEMS/posix/setBootConfigFromNVRAM.c
        modified:   modules/libcom/RTEMS/rtems_util.c
        modified:   modules/libcom/RTEMS/setBootConfigFromNVRAM.c
renamed: modules/libcom/src/osi/os/RTEMS/devLibVMEOSD.c -> modules/libcom/src/osi/os/RTEMS-kernel/devLibVMEOSD.c renamed: modules/libcom/src/osi/os/RTEMS/epicsAtomicOSD.cpp -> modules/libcom/src/osi/os/RTEMS-kernel/epicsAtomicOSD.cpp renamed: modules/libcom/src/osi/os/RTEMS/epicsAtomicOSD.h -> modules/libcom/src/osi/os/RTEMS-kernel/epicsAtomicOSD.h renamed: modules/libcom/src/osi/os/RTEMS/epicsMath.h -> modules/libcom/src/osi/os/RTEMS-kernel/epicsMath.h renamed: modules/libcom/src/osi/os/RTEMS/osdEnv.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdEnv.c renamed: modules/libcom/src/osi/os/RTEMS/osdEvent.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdEvent.c renamed: modules/libcom/src/osi/os/RTEMS/osdEvent.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdEvent.h renamed: modules/libcom/src/osi/os/RTEMS/osdFindSymbol.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdFindSymbol.c new file: modules/libcom/src/osi/os/RTEMS-kernel/osdMessageQueue.c new file: modules/libcom/src/osi/os/RTEMS-kernel/osdMessageQueue.h renamed: modules/libcom/src/osi/os/RTEMS/osdMutex.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdMutex.c renamed: modules/libcom/src/osi/os/RTEMS/osdMutex.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdMutex.h renamed: modules/libcom/src/osi/os/RTEMS/osdPoolStatus.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdPoolStatus.c renamed: modules/libcom/src/osi/os/RTEMS/osdProcess.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdProcess.c renamed: modules/libcom/src/osi/os/RTEMS/osdReadline.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdReadline.c
        new file:   modules/libcom/src/osi/os/RTEMS-kernel/osdSignal.cpp
renamed: modules/libcom/src/osi/os/RTEMS/osdSock.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdSock.h renamed: modules/libcom/src/osi/os/RTEMS/osdSpin.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdSpin.c renamed: modules/libcom/src/osi/os/RTEMS/osdStrtod.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdStrtod.h renamed: modules/libcom/src/osi/os/RTEMS/osdThread.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdThread.c renamed: modules/libcom/src/osi/os/RTEMS/osdThread.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdThread.h renamed: modules/libcom/src/osi/os/RTEMS/osdThreadExtra.c -> modules/libcom/src/osi/os/RTEMS-kernel/osdThreadExtra.c renamed: modules/libcom/src/osi/os/RTEMS/osdTime.cpp -> modules/libcom/src/osi/os/RTEMS-kernel/osdTime.cpp renamed: modules/libcom/src/osi/os/RTEMS/osdTime.h -> modules/libcom/src/osi/os/RTEMS-kernel/osdTime.h renamed: modules/libcom/src/osi/os/RTEMS/osiUnistd.h -> modules/libcom/src/osi/os/RTEMS-kernel/osiUnistd.h new file: modules/libcom/src/osi/os/RTEMS-posix/osdMessageQueue.c new file: modules/libcom/src/osi/os/RTEMS-posix/osdMessageQueue.h
        new file:   modules/libcom/src/osi/os/RTEMS-posix/osdMutex.c
new file: modules/libcom/src/osi/os/RTEMS-posix/osdPoolStatus.c
        new file:   modules/libcom/src/osi/os/RTEMS-posix/osdSock.h
        modified:   modules/libcom/src/osi/os/RTEMS/epicsMMIO.h
        modified:   modules/libcom/src/osi/os/RTEMS/osdInterrupt.c
        modified:   modules/libcom/src/osi/os/RTEMS/osdInterrupt.h
        deleted:    modules/libcom/src/osi/os/RTEMS/osdSignal.cpp
        modified:   modules/libcom/src/osi/os/RTEMS/osdVME.h
        modified:   modules/libcom/src/osi/os/RTEMS/osiFileName.h
[h1@earth QtC-epics-base (7.0 *+)]$ git commit
[7.0 27e109de4] Porting to RTEMS5 with posix and libbsd
 73 files changed, 3325 insertions(+), 380 deletions(-)
 create mode 100644 configure/os/CONFIG.Common.RTEMS-beagleboneblack
 create mode 100644 configure/os/CONFIG.Common.RTEMS-qoriq_e500
 create mode 100644 configure/os/CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
create mode 100644 configure/os/CONFIG.Common.RTEMS-xilinx_zynq_zedboard
 create mode 100644 modules/libcom/RTEMS/epicsNtp.c
 create mode 100644 modules/libcom/RTEMS/epicsNtp.h
 create mode 100644 modules/libcom/RTEMS/kernel/epicsRtemsInitHookPost.c
 create mode 100644 modules/libcom/RTEMS/kernel/epicsRtemsInitHookPre.c
 create mode 100644 modules/libcom/RTEMS/kernel/epicsRtemsInitHooks.h
 rename modules/libcom/RTEMS/{ => kernel}/rtems_config.c (91%)
 rename modules/libcom/RTEMS/{ => kernel}/rtems_init.c (93%)
 rename modules/libcom/RTEMS/{ => kernel}/rtems_netconfig.c (97%)
 create mode 100644 modules/libcom/RTEMS/kernel/setBootConfigFromNVRAM.c
 create mode 100644 modules/libcom/RTEMS/posix/epicsRtemsInitHookPost.c
 create mode 100644 modules/libcom/RTEMS/posix/epicsRtemsInitHookPre.c
 create mode 100644 modules/libcom/RTEMS/posix/epicsRtemsInitHooks.h
 create mode 100644 modules/libcom/RTEMS/posix/libbsd_netconfig.c
 create mode 100644 modules/libcom/RTEMS/posix/libbsd_netconfig.h
 create mode 100644 modules/libcom/RTEMS/posix/rtems_config.c
 create mode 100644 modules/libcom/RTEMS/posix/rtems_init.c
 create mode 100644 modules/libcom/RTEMS/posix/setBootConfigFromNVRAM.c
rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/devLibVMEOSD.c (93%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/epicsAtomicOSD.cpp (100%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/epicsAtomicOSD.h (92%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/epicsMath.h (77%)
 rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdEnv.c (79%)
rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdEvent.c (94%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdEvent.h (68%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdFindSymbol.c (72%) create mode 100644 modules/libcom/src/osi/os/RTEMS-kernel/osdMessageQueue.c create mode 100644 modules/libcom/src/osi/os/RTEMS-kernel/osdMessageQueue.h rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdMutex.c (92%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdMutex.h (68%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdPoolStatus.c (79%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdProcess.c (72%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdReadline.c (98%)
 create mode 100644 modules/libcom/src/osi/os/RTEMS-kernel/osdSignal.cpp
rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdSock.h (98%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdSpin.c (98%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdStrtod.h (64%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdThread.c (80%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdThread.h (58%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdThreadExtra.c (75%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdTime.cpp (99%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osdTime.h (96%) rename modules/libcom/src/osi/os/{RTEMS => RTEMS-kernel}/osiUnistd.h (80%) create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdMessageQueue.c create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdMessageQueue.h
 create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdMutex.c
create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdPoolStatus.c
 create mode 100644 modules/libcom/src/osi/os/RTEMS-posix/osdSock.h
 delete mode 100644 modules/libcom/src/osi/os/RTEMS/osdSignal.cpp
Re: No access to epics-base.git for push Michael Davidsaver via Core-talk
Prev: Re: Opinions please, what should this database do Ben Franksen via Core-talk
Next: Re: No access to epics-base.git for push Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: Opinions please, what should this database do Johnson, Andrew N. via Core-talk
ANJ, 31 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
