2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1902285] [NEW] caput never uses ca_get_callback()
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 30 Oct 2020 17:56:40 -0000
Public bug reported:
It would be nice to see the old and new element counts from an array
field when putting a new array to it. Currently there is no way to ask
caput to use ca_array_get_callback() to fetch those values so it can
display the current array size instead of the maximum number of
elements, it always displays the maximum number for the old and new
values.
It's not obvious that the -c flag would be appropriate for turning that
behavior on, given that we already use it to switch to using
ca_put_callback(), which changes the semantics of the put operation.
** Affects: epics-base
     Importance: Wishlist
         Status: New
** Tags: catools codeathon
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1902285
Title:
Status in EPICS Base:
  New
Bug description:
  values.
  that behavior on, given that we already use it to switch to using
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1902285/+subscriptions
Prev: epics-pva2pva-linux32 - Build # 196 - Fixed! APS Jenkins via Core-talk
Next: Re: Build failed: EPICS Base 7 base-3.15-91 Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: abi-compliance-checker and c++ Michael Davidsaver via Core-talk
Next: [Bug 1902560] [NEW] Read info items using a filter Andrew Johnson via Core-talk
ANJ, 02 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
