2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1904207] [NEW] softIocPVA calls iocInit unrequested and then complains
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 13 Nov 2020 14:09:03 -0000
Public bug reported:
Since R7.0.4.2, softIocPVA automatically calls iocInit after reading the startup script, even if iocInit had already been called in that script. In that case it complains:
iocBuild: IOC can only be initialized from uninitialized or stopped state
softIoc does not do this only softIocPVA does.
Please revert to the previous behavior which leaves the choice to the
user if iocInit should be called or not.
** Affects: epics-base
     Importance: Undecided
         Status: New
** Description changed:
- Since R7.0.4.2, softIocPVA automatically calls iocInit after reading the startup script, even if iocInit had already been called. In that case it complains:
+ Since R7.0.4.2, softIocPVA automatically calls iocInit after reading the startup script, even if iocInit had already been called in that script. In that case it complains:
  Please revert to the previous behavior which leaves the coice to the
- Please revert to the previous behavior which leaves the coice to the
+ Please revert to the previous behavior which leaves the choice to the
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1904207
Title:
Status in EPICS Base:
  New
Bug description:
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1904207/+subscriptions
[Bug 1904207] Re: softIocPVA calls iocInit unrequested and then complains Timo Korhonen via Core-talk
[Bug 1904207] Re: softIocPVA calls iocInit unrequested and then complains mdavidsaver via Core-talk
Prev: [Bug 1903924] Re: The aao record type could use a DOL input link Dirk Zimoch via Core-talk
Next: [Bug 1904207] Re: softIocPVA calls iocInit unrequested and then complains Timo Korhonen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 18 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
