2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Problems with hanging osiSockTest
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: EPICS core-talk <core-talk at aps.anl.gov>
Date: Wed, 18 Nov 2020 14:58:29 +0000
Begin forwarded message:
Subject: AW: Problems with hanging osiSockTest
Date: November 18, 2020 at 6:34:06 AM CST
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>, "Johnson, Andrew N." <anj at anl.gov>
$ ifconfig
enp0s31f6: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 129.129.130.117  netmask 255.255.255.0  broadcast 129.129.130.255
        inet6 fe80::42b0:34ff:feea:5428  prefixlen 64  scopeid 0x20<link>
        ether 40:b0:34:ea:54:28  txqueuelen 1000  (Ethernet)
        RX packets 54764087  bytes 24015803269 (22.3 GiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 55167521  bytes 54881613829 (51.1 GiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 16  memory 0xe1200000-e1220000
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 1322943  bytes 739804353 (705.5 MiB)
        TX packets 1322943  bytes 739804353 (705.5 MiB)
virbr0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 192.168.122.1  netmask 255.255.255.0  broadcast 192.168.122.255
        ether 52:54:00:15:9b:3e  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
Von: Core-talk <core-talk-bounces at aps.anl.gov> Im Auftrag von Zimoch Dirk (PSI) via Core-talk
Gesendet: Mittwoch, 18. November 2020 13:33
An: Johnson, Andrew N. <anj at anl.gov>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Betreff: AW: Problems with hanging osiSockTest
After this:
1..24
ok  1 - osiSockAttach
# udpSockTest()
ok  2 - epicsSocketCreate INET, DGRAM, 0
ok  3 - setsockopt BROADCAST := 1
ok  4 - getsockopt BROADCAST => 1
ok  5 - setsockopt BROADCAST := 0
ok  6 - getsockopt BROADCAST => 0
ok  7 - setsockopt MULTICAST_LOOP := 1
ok  8 - getsockopt MULTICAST_LOOP => 1
ok  9 - setsockopt MULTICAST_LOOP := 0
ok 10 - getsockopt MULTICAST_LOOP => 0
ok 11 - setsockopt IP_MULTICAST_TTL := 2
ok 12 - getsockopt IP_MULTICAST_TTL => 2
ok 13 - setsockopt IP_MULTICAST_TTL := 1
ok 14 - getsockopt IP_MULTICAST_TTL => 1
# udpSockFanoutBindTest()
# First test if epicsSocketEnableAddressUseForDatagramFanout() is necessary
ok 15 - bind() to port 43731
ok 16 - bind() to 43731 error -1, 98
# Now the real test
ok 17 - bind() to port 43731
ok 18 - bind() to port 43731
# udpSockFanoutTest()
# Interface 129.129.130.255:5064
# Not LO
# RX1 start
# RX2 start
# RX ignore
# RX ignore
# RX2 success 0
# RX1 success 0
# RX ignore
# RX ignore
# RX ignore
# RX ignore
# RX ignore
# RX ignore
# RX2 success 1
# RX1 success 1
# RX ignore
# RX ignore
# RX2 success 2
# RX1 success 2
# RX ignore
# RX ignore
# RX2 success 3
# RX1 success 3
# RX ignore
# RX ignore
# RX ignore
# RX ignore
# RX1 success 4
# RX2 success 4
# RX ignore
# RX ignore
# RX ignore
# RX ignore
# RX1 success 5
# RX1 end
# RX2 success 5
# RX2 end
# Result: RX1 3f:0 RX2 3f:0
# Interface 192.168.122.255:5064
# Not LO
# RX1 start
# RX2 start
# RX ignore
Now it repeatedly prints "# RX ignore" forever...
Von: Johnson, Andrew N. <anj at anl.gov>
Gesendet: Dienstag, 17. November 2020 18:11
An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
Betreff: Re: Problems with hanging osiSockTest
Dirk,
What happens if you run that test manually? All EPICS unit tests can be run individually without using the test harness to see more details as the test proceeds. This is my output on RHEL-7.8, which takes about 6 seconds to run:
tux% cd modules/libcom/test/O.linux-x86_64/
tux% ./osiSockTest
1..24
# udpSockTest()
ok 15 - bind() to port 55467
ok 16 - bind() to 55467 error -1, 98
# Now the real test
ok 17 - bind() to port 55467
ok 18 - bind() to port 55467
# Interface 164.54.11.255:5064
# Not LO
# RX1 start
# RX2 start
# RX2 success 0
# RX1 success 0
# RX2 success 1
# RX1 success 1
# RX2 success 2
# RX1 success 2
# RX ignore
# RX ignore
# RX1 success 3
# RX2 success 3
# RX2 success 4
# RX1 success 4
# RX1 success 5
# RX1 end
# RX2 success 5
# RX2 end
# Not LO
# RX1 start
# RX2 start
# RX1 success 0
# RX2 success 0
# RX1 success 1
# RX2 success 1
# RX1 success 2
# RX2 success 2
# RX ignore
# RX ignore
# RX1 success 3
# RX2 success 3
# RX1 success 4
# RX2 success 4
# RX1 success 5
# RX1 end
# RX2 success 5
# RX2 end
ok 19 - Found non-loopback interface
ok 20 - Successes 2
# tcpSockReuseBindTest(0)
ok 21 - bind() to port 53058
ok 22 - bind() to 53058 error -1, 98
# tcpSockReuseBindTest(1)
# epicsSocketEnableAddressReuseDuringTimeWaitState
ok 23 - bind() to port 34068
ok 24 - bind() to 34068 error -1, 98
    Results
       Tests: 24
      Passed:  24 = 100.00%
- Andrew
On Nov 17, 2020, at 4:47 AM, Zimoch Dirk (PSI) via Core-talk <core-talk at aps.anl.gov> wrote:
Hello everybody,
I have problems with a test in EPICS 7 commit 8fd36d8eef3420b42e7936e949928a6b43df7e15.
osiSockTest seems to take forever.
'make runtests' hangs here:
osiSockTest.t ................. 1/24
'make tapfiles' hangs here:
perl -CSD osiSockTest.t -tap > osiSockTest.tap
I am testing on RedHat 7 (linux-x86_64).
Any ideas?
Dirk
Complexity comes for free, simplicity you have to work for.
Prev: [Bug 1776141] Re: Buffer overrun in dbpr with long INP field Martin Konrad via Core-talk
Next: Build completed: epics-base base-integration-37 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: AW: AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Next: Build failed: epics-base base-dbChannelForDBLinks-599 AppVeyor via Core-talk
ANJ, 23 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
