2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: another git question
From: "Konrad, Martin via Core-talk" <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>, "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Wed, 18 Nov 2020 16:58:38 +0000
Hi Dirk,
"git rebase" _moves_ a branch with a series of commits on top of another
branch. For example you can use it to rebase a branch you worked on for
a while on top of the latest version of the mainline branch before
creating a pull request. Rebasing puts the burden of resolving potential
conflicts on the contributor rather than the guy pressing the merge
button which is why Linus Torvalds implemented this feature :-)
"git cherry-pick" _copies_ a single commit to the current position in
the git history. It's a great tool for backporting a change to an older
branch without getting all the other commits.
From what you're describing cherry-picking sounds like the way to go.
You can cherry-pick from the 7.0 branch to 3.14 or the other way around.
Note that cherry-picking might fail if the code snipped the change
applies to has changed.
-Martin
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: konrad at frib.msu.edu
another git question Zimoch Dirk (PSI) via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: another git question Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: another git question Zimoch Dirk (PSI) via Core-talk
ANJ, 18 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
