2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: AW: AW: AW: Problems with hanging osiSockTest
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Fri, 20 Nov 2020 08:49:28 +0000
Which this change, the tests terminates and succeeds.
Please do not have variable declarations after instructions in C (non C++) code. Not all compilers like that. I already had to fix udpSockFanoutTestRx() because of this problem:
@@ -213,6 +213,7 @@ void udpSockFanoutTestRx(void* raw)
     struct TInfo *info = raw;
     epicsTimeStamp start, now;
+    unsigned nremain = nrepeat;
 #ifdef _WIN32
     /* ms */
     DWORD timeout = 10000;
@@ -222,7 +223,6 @@ void udpSockFanoutTestRx(void* raw)
     timeout.tv_sec = 10;
     timeout.tv_usec = 0;
 #endif
-    unsigned nremain = nrepeat;
     (void)epicsTimeGetCurrent(&start);
     now = start;
Dirk
> -----Ursprüngliche Nachricht-----
> Von: Michael Davidsaver <mdavidsaver at gmail.com>
> Gesendet: Donnerstag, 19. November 2020 19:24
> An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
> Cc: Johnson, Andrew N. <anj at anl.gov>; EPICS core-talk <core-
> Betreff: Re: AW: AW: Problems with hanging osiSockTest
> On 11/19/20 2:27 AM, Zimoch Dirk (PSI) wrote:
> > I have tested the latest 7.0 commit.
> > osiSockTest still hangs on the virbr0 interface:
> Ha.  I see why my attempt to have this test timeout is broken.
> > diff --git a/modules/libcom/test/osiSockTest.c
> b/modules/libcom/test/osiSockTest.c
> > index e71eec5fe..a3b831b66 100644
> > --- a/modules/libcom/test/osiSockTest.c
> > +++ b/modules/libcom/test/osiSockTest.c
> > @@ -239,6 +239,8 @@ void udpSockFanoutTestRx(void* raw)
> >          osiSockAddr src;
> >          osiSocklen_t srclen = sizeof(src);
> > +        (void)epicsTimeGetCurrent(&now);
> >          int n = recvfrom(info->sock, buf.bytes, sizeof(buf.bytes), 0, &src.sa,
> &srclen);
> >          buf.bytes[sizeof(buf.bytes)-1] = '\0';
Re: AW: AW: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Re: Problems with hanging osiSockTest Johnson, Andrew N. via Core-talk
AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Re: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
AW: AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Re: AW: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
Prev: AW: AW: Problems with hanging osiSockTest Zimoch Dirk (PSI) via Core-talk
Next: Re: another git question Yendell, Gary (DLSLtd, RAL, LSCI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: AW: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
Next: Re: AW: AW: AW: Problems with hanging osiSockTest Michael Davidsaver via Core-talk
ANJ, 20 Nov 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
