2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: Heinz Junkes via Core-talk <core-talk at aps.anl.gov>
To: mp+394327 at code.launchpad.net
Date: Sun, 20 Dec 2020 14:11:18 -0000
Yes, even RTEMS5 without the new libbsd-network-stack has not defined _XOPEN_SOURCE and asks for the old implementation. I can set _XOPEN_SOURCE by hand and it works so far with it. But what I noticed in this context and I think that the mutexes may be used incorrectly in some modules and therefore it comes to problems such as: "mutex not owned by the task".
I saw the whole thing in the context of MotorRecords (OMS):
https://github.com/epics-modules/motor/issues/172
I see a general problem that probably in some places mutexes are created in the iocInit task and then used afterwards in other tasks although the iocInit task has been terminated.
As I understand it, mutexes should generally be created in the tasks in which they are also used? Or with shared memory the creating task must remain however existing?
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Build failed: EPICS Base 3.15 base-3.15-28 AppVeyor via Core-talk
Next: Re: -Werror=implicit-function-declaration by default? Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 20 Dec 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
