2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Appveyor Settings for the 3.15 (and 7.0) branch builds
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Wed, 23 Dec 2020 13:41:30 +0100
That's exactly what I had tried and reported as not working a few weeks ago in one of our Core meetings, before I pointed them back to the gists.
Thanks for confirming this weird behaviour.
Michael was suggesting to try renaming the .appveyor.yml (maybe to .appveyor-3.15.yml) on the branch and set that name in the web UI. I didn't try that yet.
Their documentation says the setting either is a different file name (then read from within the repository through the GitHub API) or a URL.
Cheers,
~Ralph
On Wed, 23 Dec 2020 at 01:33, Johnson, Andrew N. via Core-talk <core-talk at aps.anl.gov> wrote:
I thought I understood Appveyor's need for a pointer to get the .appveyor.yml file from when building our epics-base-3 and epics-base-7 projects. The other day I had a brainwave that the “Custom configuration .yml file name” setting could be pointed to the raw link for that file on the appropriate branch, thus avoiding the need to separately update a gist every time we want to change that file.
However that doesn’t seem to work, I can’t get the epics-base-3 branch to see the last change I committed to that file on the 3.15 branch:
commit 436ce4526be7d4ce24859c23dd0e71119ca70d50 (HEAD -> 3.15, origin/3.15)
Author: Andrew Johnson <anj at anl.gov>
Date:   Mon Dec 21 15:49:52 2020 -0600
    Appveyor: Update CMP from mingw => gcc
diff --git a/.appveyor.yml b/.appveyor.yml
index 4e5811ee4..1bcba4648 100644
--- a/.appveyor.yml
+++ b/.appveyor.yml
@@ -68,7 +68,7 @@ environment:
   - CMP: vs2013
   - CMP: vs2012
   - CMP: vs2010
-  - CMP: mingw
+  - CMP: gcc
 # Platform: processor architecture
 platform:
I just pointed it back to my gist and that seems to be working. Any ideas why it will happily accept
but not
- Andrew (frustrated by MS as usual)
Complexity comes for free, simplicity you have to work for.
Re: Appveyor Settings for the 3.15 (and 7.0) branch builds Johnson, Andrew N. via Core-talk
Prev: Build completed: EPICS Base 3.15 base-3.15-29 AppVeyor via Core-talk
Next: Re: Appveyor Settings for the 3.15 (and 7.0) branch builds Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Appveyor Settings for the 3.15 (and 7.0) branch builds Johnson, Andrew N. via Core-talk
ANJ, 23 Dec 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
