2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Bug 1910148] Re: Broadcast address detection is unreliable on Linux
From: Chris Johns via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 8 Jan 2021 12:21:01 +1100
On 6/1/21 2:47 am, mdavidsaver via Core-talk wrote:
> Do you mean your patch to be a proof of concept, or to be accepted as
> is?  If the later, compatibility with the embedded RTOS targets (RTEMS
> 4.x and vxWorks) needs to be maintained.  These targets do not provide
> getifaddrs(), and would fail to compile with getifaddrs.patch.
Just thought I would mention RTEMS 5 provides getifaddrs. It is present in
source for the RTEMS legacy networking code and the newer rtems-libbsd
networking stack we now provide. As indicated elsewhere in this thread there is
no defines to indicate it is available.
Chris
Re: [Bug 1910148] Re: Broadcast address detection is unreliable on Linux Johnson, Andrew N. via Core-talk
[Bug 1910148] [NEW] Broadcast address detection is unreliable on Linux Michael Ritzert via Core-talk
[Bug 1910148] Re: Broadcast address detection is unreliable on Linux mdavidsaver via Core-talk
Prev: [Bug 1910148] Re: Broadcast address detection is unreliable on Linux Andrew Johnson via Core-talk
Next: Re: [Bug 1910148] Re: Broadcast address detection is unreliable on Linux Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1910148] Re: Broadcast address detection is unreliable on Linux mdavidsaver via Core-talk
ANJ, 07 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
