2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mp+396197 at code.launchpad.net
Date: Thu, 14 Jan 2021 10:58:42 -0000
So far, looking at what changed between the current HEAD and the version I originally based my changes on, I have only considered changes under modules/database. I will now also consider the possibility that some changes outside of modules/database e.g. in modules/ca have invalidated my patch.
It is very unfortunate that some of the changes that happened in the meantime are bulk changes to things like copyright header comments because that means almost every file has been touched.
https://code.launchpad.net/~bfrk/epics-base/+git/epics-base/+merge/396197
Your team EPICS Core Developers is requested to review the proposed merge of ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0.
[Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Prev: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
Next: Re: Question about travis-ci Torsten Bögershausen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
ANJ, 14 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
