2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-3.15 #263
From: Jenkins EPICS PSI via Core-talk <core-talk at aps.anl.gov>
To: <dirk.zimoch at psi.ch>, <core-talk at aps.anl.gov>
Date: Tue, 26 Jan 2021 19:02:35 +0100
See <http://gfa-sls2-test:8080/job/EPICS-3.15/263/display/redirect?page=changes>
Changes:
[ralph.lange] Build: Fix spurious failures with SNIPPETS in Windows
Started by an SCM change
Building in workspace <http://gfa-sls2-test:8080/job/EPICS-3.15/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Deferred wipeout is used...
[WS-CLEANUP] Done
Cloning the remote Git repository
Cloning repository https://git.launchpad.net/epics-base
 > git init <http://gfa-sls2-test:8080/job/EPICS-3.15/ws/> # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
 > git --version # timeout=10
 > git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
 > git config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
 > git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git rev-parse origin/3.15^{commit} # timeout=10
Checking out Revision dd9f38d7112d21b010ac6334b230e113b1338e1d (origin/3.15)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f dd9f38d7112d21b010ac6334b230e113b1338e1d
Commit message: "Build: Fix spurious failures with SNIPPETS in Windows"
 > git rev-list --no-walk d997690aa5645ff2dd08c5ad794244806600a132 # timeout=10
[EPICS-3.15] $ /bin/sh -xe /tmp/jenkins4325085158476072853.sh
+ tar xfz /net/sls-hafs/export/exchange/home/zimoch/epics/PSIconfig.tgz
tar (child): /net/sls-hafs/export/exchange/home/zimoch/epics/PSIconfig.tgz: Cannot open: Permission denied
tar (child): Error is not recoverable: exiting now
gzip: stdin: unexpected end of file
tar: Child returned status 2
tar: Error is not recoverable: exiting now
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : EPICS-3.15 #264 Jenkins EPICS PSI via Core-talk
Build failed in Jenkins: EPICS-3.15 #262 Jenkins EPICS PSI via Core-talk
Prev: [Bug 1815864] Re: Assemblies fail to work on Windows Ralph Lange via Core-talk
Next: epics-7.0 - Build # 284 - Unstable! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: EPICS-3.15 #262 Jenkins EPICS PSI via Core-talk
Next: Jenkins build is back to normal : EPICS-3.15 #264 Jenkins EPICS PSI via Core-talk
ANJ, 27 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
