2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: A general question about convert e.g. in longout record drvh, drvl handling
From: Heinz Junkes via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Wed, 27 Jan 2021 12:53:13 +0100
Yes, the Idea with DOL/OMSL is a good one ;-)
And thanks for the clear answer about drvl = drvh = 0.
Unfortunately I had not thought of that at that moment. Makes total sense.
But maybe it would be worth to exclude the "0" (default) in the convert
or to give a warning when loading the db file with DRVH = DRVL (!0)?
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
> On 27. Jan 2021, at 12:08, Ralph Lange via Core-talk <core-talk at aps.anl.gov> wrote:
> On Wed, 27 Jan 2021 at 11:56, Heinz Junkes via Core-talk <core-talk at aps.anl.gov> wrote:
> I have defined a longout record and wanted to achieve that you can set exactly only one value.
> Wouldn't a constant DOL and OMSL set to supervisory achieve that?
> Cheers,
> ~Ralph
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: A general question about convert e.g. in longout record drvh, drvl handling Johnson, Andrew N. via Core-talk
AW: A general question about convert e.g. in longout record drvh, drvl handling Zimoch Dirk (PSI) via Core-talk
A general question about convert e.g. in longout record drvh, drvl handling Heinz Junkes via Core-talk
Re: A general question about convert e.g. in longout record drvh, drvl handling Ralph Lange via Core-talk
Prev: Re: A general question about convert e.g. in longout record drvh, drvl handling Ralph Lange via Core-talk
Next: Re: Unit tests on Windows DLL internals Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: A general question about convert e.g. in longout record drvh, drvl handling Johnson, Andrew N. via Core-talk
ANJ, 28 Jan 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
