2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: CaSe-IndepeDent Menu SEARches?
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Wed, 3 Feb 2021 17:23:33 -0800
On 2/3/21 4:21 PM, Johnson, Andrew N. via Core-talk wrote:
> A colleague just presented me with one of those frustrating little problems where his database wouldn’t load because he spelled a calcout.OOPT field value using “to” instead of “To” and he couldn’t find it.
Menu strings are certainly a gotcha which gets me.
For me, even after a decade I _still_ try to set SCAN to "10 seconds".
I think I have some kind of mental block at this point.
I don't see case as being particularly special though, and I'm not a
fan of relaxing strictness.  Nor of changing all of the other parsers.
(Are you volunteering to handle VDCT?)
How about improving the error message by printing the choices list from
dbPutString() in a way which invites copy+paste?
> Can't set "foo.SCAN" to "10 seconds" Extraneous characters
> Error at or before ")" in path "."  file "badchoice.db" line 2
> dbLoadRecords: failed to load 'badchoice.db'
> Error: Failed to load: badchoice.db
might become
> Menu Choices:
>   "Passive"
>   "Event"
>   "I/O Intr"
>   "10 second"
>   "5 second"
>   "2 second"
>   "1 second"
>   ".5 second"
>   ".2 second"
>   ".1 second"
> How about when putting to a menu field we do a second pass through the choice strings using epicsStrCaseCmp() so this kind of thing would be silently accepted? The first pass should still use strcmp() in case some IOC has choices (in mbbo strings) that only differ by case, but the second pass would accept the first to match even when the cases differ.
> We could make this configurable so sites could turn it off, or even have it display a warning, but I’m not sure who would really want that much strictness.
> I already wrote the code, although it could be posted as a Codeathon project instead (requiring tests and Release Notes as well).
> - Andrew
> Complexity comes for free, simplicity you have to work for.
Re: CaSe-IndepeDent Menu SEARches? Michael Davidsaver via Core-talk
CaSe-IndepeDent Menu SEARches? Johnson, Andrew N. via Core-talk
Prev: CaSe-IndepeDent Menu SEARches? Johnson, Andrew N. via Core-talk
Next: Re: CaSe-IndepeDent Menu SEARches? Torsten Bögershausen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: CaSe-IndepeDent Menu SEARches? Michael Davidsaver via Core-talk
ANJ, 04 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
