2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Information request on RTEMS 6+ needs/wants
From: Heinz Junkes via Core-talk <core-talk at aps.anl.gov>
To: Gedare Bloom <gedare at rtems.org>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>, Joel Sherrill <joel at rtems.org>
Date: Fri, 12 Feb 2021 11:16:05 +0100
Good morning Gedare,
Now I'll get in touch with you too.
Unfortunately, I haven't really gotten around to continuing with RTEMS this year.
Fortunately, Brendan Chandler has tried to bring everything together here.
Andrew has already pointed this out:
"Progress on our RTEMS-5 port of EPICS Base can be followed at this GitHub PR.” :
https://github.com/epics-base/epics-base/pull/105
For me it looks like this at the moment:
I use RTEMS5 und EPICS7 with the MVME6100 in production.
Unfortunately I can't use libbsd because the ethernet controller of the board is not supported.
I tried to convert the driver from Till Strauman to the nexus driver, but unfortunately didn't get
it done in 2-3 days and then aborted. Also there is no PCI/VMEbus support yet in the
libbsd. I also still use the rudimentary VME, NTP support and Till's NFS (v2).
I am satisfied with this so far in our environment. But other labs would like to use the MVME6100
(MVME5500) with NFS3, NTP (PTP2) and especially VMEbus and loadable modules(lib).
If I have noticed correctly there is funding for dyn link loader (by HZB, Bessy)
and NFS3 (by Gemini) for RTEMS5/6 and libbsd.
I have the MVME2500 (qoriq_e500) running quite well with libbsd and Till's NFS2.
I miss the support for PCI/VMEbus, Time-client (NTP, PTP2) and RTC.
I would like to use my new playground (MTCa4, IFC1420, FPGA) also with RTEMS. The board
is also a Qoriq based system. But again, support for PCI will be critical. I couldn't try anything yet though.
I am currently developing EPICS7 with RTEMS5 and libbsd on xilinx_zynq_a9_qemu. This works so far quite ok.
(I haven't managed to boot an image on the xilinx_zynq_a9 hardware with U-Boot yet, though, unfortunately).
Viele Grüße
Heinz
> On 11. Feb 2021, at 21:32, Gedare Bloom via Core-talk <core-talk at aps.anl.gov> wrote:
> Hello again EPICS Core,
> I'm looking to collect some feedback from you all related to
> EPICS+RTEMS. I'm trying to also keep in touch with monitoring the
> progress on EPICS7/RTEMS5 (And, I'm planning to participate with
> students in the upcoming hackathon! if you have tasks related, I might
> be able to help knock them out). My ask right now is:
> * What feature improvements would you like to see in future RTEMS releases?
> * What are your pain points with current RTEMS versions and/or workflows?
> And anything else positive/negative you'd like to put out here is
> certainly welcome.
> -Gedare
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: Information request on RTEMS 6+ needs/wants Gedare Bloom via Core-talk
Prev: Build failed: epics-base base-integration-621 AppVeyor via Core-talk
Next: Re: Information request on RTEMS 4.10 needs/wants Gedare Bloom via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Information request on RTEMS 6+ needs/wants Gedare Bloom via Core-talk
Next: Re: Information request on RTEMS 6+ needs/wants Gedare Bloom via Core-talk
ANJ, 12 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
