2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1714455] Re: change request: filters should allow 'relaxed JSON'
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 26 Feb 2021 17:39:29 -0000
** Changed in: epics-base/7.0
       Status: In Progress => Fix Committed
    Milestone: None => 7.0.5
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1714455
Title:
Status in EPICS Base:
  Fix Committed
Status in EPICS Base 7.0 series:
  Fix Committed
Bug description:
  For the sake of easier typing, shorter channel names, improved
  readability and consistency, CA filters should allow the same
  simplified (or 'relaxed') JSON syntax as the 3.16 DB parser already
  allows, that is skipping the quotes around field names.
  For example instead of
  caget 'test:channel.{"arr":{"s":2,"i":2,"e":8}}'
  allow
  caget test:channel.{arr:{s:2,i:2,e:8}}
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1714455/+subscriptions
Prev: Build failed in Jenkins: 3.15-example-win64s #228 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-example-win64 #616 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Build failed: EPICS Base 7 base-7.0-171 AppVeyor via Core-talk
Next: [Bug 1714455] Re: change request: filters should allow 'relaxed JSON' Andrew Johnson via Core-talk
ANJ, 28 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
