2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1182091] Re: Make TIME field directly accessible
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 08 Mar 2021 23:35:42 -0000
Summing up our Zoom discussion: The ts post filter should be able to
allocate a new db_field_log and convert the timestamp from the
pLog->time field into a new value of whatever type/format was requested
by the filter args.
My preference would be that ts:{fmt="%Y-%m-%d %H:%M:%S.%09f"} would
return a DBF_STRING (although Michael isn't keen on accepting format
strings from the network for security reasons; we can discuss that),
while say ts:{epoch:1970} would return a double giving the number of
seconds since 1970-01-01 00:00:00 UTC (that being the Posix epoch, while
for 1990 it would use the EPICS epoch).
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1182091
Title:
Status in EPICS Base:
  Triaged
Bug description:
  Users often request the ability to access the TIME field directly.
  It could be provided as an array of 2 32-bit values, possibly with a specific string in ISO-8601 form say.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1182091/+subscriptions
Prev: [Bug 1905159] Re: Fix warnings from recent compiler versions Andrew Johnson via Core-talk
Next: Re: ANN: RTEMS libnetworking relocation Vijay Kumar Banerjee via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1182091] Re: Make TIME field directly accessible Jure Varlec via Core-talk
Next: [Bug 1182091] Re: Make TIME field directly accessible Ben Franksen via Core-talk
ANJ, 09 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
