2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1918762] [NEW] rset::get_enum_str() API problem
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 11 Mar 2021 23:38:53 -0000
Public bug reported:
The recSup.h typed_rset get_enum_str() method has this prototype:
    long (*get_enum_str)(const struct dbAddr *paddr, char *pbuffer);
The method gets no indication how large pbuffer is, so it's easy for it
to overflow it, although not by much.
The bi and bo records both hope it's one byte longer than their
associated ZNAM/ONAM fields (which are 26 bytes long) because they call
strncpy(pbuffer,,26) and then write a nil byte to pbuffer[26].
The mbbi and mbbo records at least don't overflow the buffer they assume
is 26 bytes long since they don't bother writing the nil byte after
calling strncpy(pbuffer,,26).
No other record types in Base define this method, which isn't trivial to
get called. I think this database should be doing it when lsi gets
processed, although valgrind doesn't seem to notice the overflow:
record(bi, bi) {
  field(ZNAM, "26-character-enum-string.")
record(lsi, "lsi") {
  field(SIZV, 16)  # This is the minimum that lsi actually uses.
  field(INP, "bi")
** Affects: epics-base
     Importance: Medium
         Status: Triaged
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1918762
Title:
Status in EPICS Base:
  Triaged
Bug description:
  it to overflow it, although not by much.
  call strncpy(pbuffer,,26) and then write a nil byte to pbuffer[26].
  assume is 26 bytes long since they don't bother writing the nil byte
  after calling strncpy(pbuffer,,26).
  to get called. I think this database should be doing it when lsi gets
  record(bi, bi) {
    field(INP, "bi")
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1918762/+subscriptions
Prev: [Bug 1905159] Re: Fix warnings from recent compiler versions Andrew Johnson via Core-talk
Next: Build failed: epics-base base-integration-659 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Build failed: epics-base base-integration-656 AppVeyor via Core-talk
ANJ, 11 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
