2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1918617] Re: osiSockTest fails
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 12 Mar 2021 10:03:58 -0000
Turns out it is a firewall problem (at least on CentOS 8).
Switching off the firewall makes the test succeed.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1918617
Title:
  osiSockTest fails
Status in EPICS Base:
  New
Bug description:
  osiSockTest reports one failure:
  # udpSockFanoutTest()
  # Interface 10.0.2.255:5064
  # Not LO
  # RX2 start
  # RX1 start
  # recvfrom error (11)
  # RX1 end
  # RX2 end
  # Result: RX1 0:0 RX2 0:0
  # Interface 192.168.122.255:5064
  # Not LO
  # RX1 start
  # RX2 start
  # RX2 end
  # RX1 end
  ok 19 - Found non-loopback interface
  not ok 20 - Successes 0
  The code is in line 403:
      testOk(nsuccess>0, "Successes %u", nsuccess);
  Here is my ifconfig:
  enp0s3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
          inet 10.0.2.15  netmask 255.255.255.0  broadcast 10.0.2.255
          inet6 fe80::d9c8:1c30:9271:e21a  prefixlen 64  scopeid 0x20<link>
          ether 08:00:27:e4:35:68  txqueuelen 1000  (Ethernet)
          RX packets 262876  bytes 333781671 (318.3 MiB)
          RX errors 0  dropped 0  overruns 0  frame 0
          TX packets 74111  bytes 6531238 (6.2 MiB)
          TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
  lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
          inet 127.0.0.1  netmask 255.0.0.0
          inet6 ::1  prefixlen 128  scopeid 0x10<host>
          loop  txqueuelen 1000  (Local Loopback)
          RX packets 8721  bytes 875985 (855.4 KiB)
          TX packets 8721  bytes 875985 (855.4 KiB)
  virbr0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
          inet 192.168.122.1  netmask 255.255.255.0  broadcast 192.168.122.255
          ether 52:54:00:8e:4b:63  txqueuelen 1000  (Ethernet)
          RX packets 0  bytes 0 (0.0 B)
          TX packets 0  bytes 0 (0.0 B)
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1918617/+subscriptions
[Bug 1918617] [NEW] osiSockTest fails Dirk Zimoch via Core-talk
Prev: Re: IPv6 Jeong Han Lee via Core-talk
Next: [Bug 1918275] Re: dbdToHtml needs better error messages Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1918617] [NEW] osiSockTest fails Dirk Zimoch via Core-talk
Next: [Bug 1918617] Re: osiSockTest fails mdavidsaver via Core-talk
ANJ, 30 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
