2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-example-linux32 #852
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 1 Apr 2021 11:51:21 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-example-linux32/852/display/redirect>
Changes:
Started by upstream project "epics-pvDatabase-linux32" build number 488
originally caused by:
 Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on linux32-1 (linux32) in workspace <https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/>
The recommended git tool is: NONE
No credentials specified
 > git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://github.com/epics-base/exampleCPP.git # timeout=10
Cleaning workspace
 > git rev-parse --verify HEAD # timeout=10
Resetting working tree
 > git reset --hard # timeout=10
 > git clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/exampleCPP.git
 > git --version # timeout=10
 > git --version # 'git version 1.7.1'
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --progress https://github.com/epics-base/exampleCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git rev-parse refs/remotes/origin/master^{commit} # timeout=10
Checking out Revision 3d888491c114cd313bdb28c4aabf85a6054249e7 (refs/remotes/origin/master)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 3d888491c114cd313bdb28c4aabf85a6054249e7 # timeout=10
Commit message: "Merge pull request #60 from epics-base/access-security"
 > git rev-list --no-walk 3d888491c114cd313bdb28c4aabf85a6054249e7 # timeout=10
[epics-example-linux32] $ /bin/sh -xe /tmp/jenkins1429396851765070890.sh
+ echo 'PVDATABASE = /local/jenkins/workspace/epics-pvDatabase-linux32'
+ echo 'PVACLIENT = /local/jenkins/workspace/epics-pvaClient-linux32'
+ echo 'PVA2PVA = /local/jenkins/workspace/epics-pva2pva-linux32'
+ echo 'PVACCESS = /local/jenkins/workspace/epics-pvAccess-linux32'
+ echo 'NORMATIVE = /local/jenkins/workspace/epics-normativeTypes-linux32'
+ echo 'PVDATA = /local/jenkins/workspace/epics-pvData-linux32'
+ echo 'PVCOMMON = /local/jenkins/workspace/epics-pvCommon-linux32'
+ echo 'EPICS_BASE = /local/jenkins/workspace/epics-base-3.16-linux32'
+ make linux-x86
make -C ./configure linux-x86
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/configure'>
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/makeMakefile.pl O.linux-x86 ../..
mkdir -p O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/configure/O.linux-x86'>
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/convertRelease.pl checkRelease
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/configure/O.linux-x86'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/configure'>
make -C ./database linux-x86
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database'>
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/configure'>
mkdir -p O.Common
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/configure/O.linux-x86'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/configure/O.linux-x86'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/configure'>
make -C ./src linux-x86
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/src'>
mkdir -p O.Common
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/src/O.linux-x86'>
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleHelloRPCClient.d  ../exampleHelloRPCClient.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleDatabaseMain.d  ../exampleDatabaseMain.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleSoftRecordRegister.d  ../exampleSoftRecordRegister.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleDatabaseRegister.d  ../exampleDatabaseRegister.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleDatabase.d  ../exampleDatabase.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleHelloRPCRecord.d  ../exampleHelloRPCRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleSoftRecord.d  ../exampleSoftRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF exampleHelloRecord.d  ../exampleHelloRecord.cpp
Installing dbd file ../../dbd/exampleDatabaseRegister.dbd
mkdir ../../dbd
Installing dbd file ../../dbd/exampleSoftRecordRegister.dbd
Installing generic include file ../../include/pv/exampleHelloRecord.h
mkdir ../../include
mkdir ../../include/pv
Installing generic include file ../../include/pv/exampleHelloRPCRecord.h
Installing generic include file ../../include/pv/exampleSoftRecord.h
Installing generic include file ../../include/pv/exampleDatabase.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -c ../exampleHelloRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -c ../exampleSoftRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -c ../exampleHelloRPCRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvaClient-linux32/include   -I/local/jenkins/workspace/epics-pva2pva-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include    -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -c ../exampleDatabase.cpp
../exampleDatabase.cpp:21:28: error: pv/traceRecord.h: No such file or directory
../exampleDatabase.cpp:22:29: error: pv/removeRecord.h: No such file or directory
../exampleDatabase.cpp:23:26: error: pv/addRecord.h: No such file or directory
../exampleDatabase.cpp: In static member function ���static void epics::exampleCPP::database::ExampleDatabase::create()���:
../exampleDatabase.cpp:267: error: ���TraceRecord��� has not been declared
../exampleDatabase.cpp:269: error: ���RemoveRecord��� has not been declared
../exampleDatabase.cpp:271: error: ���AddRecord��� has not been declared
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_BUILD:242: recipe for target 'exampleDatabase.o' failed
make[3]: *** [exampleDatabase.o] Error 1
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/src/O.linux-x86'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_ARCHS:62: recipe for target 'linux-x86' failed
make[2]: *** [linux-x86] Error 2
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database/src'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_DIRS:84: recipe for target 'src.linux-x86' failed
make[1]: *** [src.linux-x86] Error 2
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-example-linux32/ws/database'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_DIRS:84: recipe for target 'database.linux-x86' failed
make: *** [database.linux-x86] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: test/O.*/*.tap
Did not find any matching files.
Jenkins build is back to normal : epics-example-linux32 #853 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: 3.15-pvDatabase-win64 #347 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-example #714 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : 3.15-pvDatabase-win64 #355 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-example-linux32 #853 APS Jenkins via Core-talk
ANJ, 08 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
