2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: 3.15-example-win64 #238
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 1 Apr 2021 13:34:46 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/3.15-example-win64/238/display/redirect?page=changes>
Changes:
[mrkraimer] use WPtr to link record
[mrkraimer] if link record is gone reset WPtr
[mrkraimer] 1) pvaClient and pvaClientMultiChannel are new
[mrkraimer] changes for latest pvDatabaseCPP
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/>
The recommended git tool is: NONE
No credentials specified
 > C:/Program Files/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files/Git/cmd/git.exe config remote.origin.url https://github.com/epics-base/exampleCPP.git # timeout=10
Cleaning workspace
 > C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
 > C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
 > C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/exampleCPP.git
 > C:/Program Files/Git/cmd/git.exe --version # timeout=10
 > git --version # 'git version 2.20.1.windows.1'
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files/Git/cmd/git.exe fetch --tags --force --progress -- https://github.com/epics-base/exampleCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
 > C:/Program Files/Git/cmd/git.exe rev-parse "refs/remotes/origin/master^{commit}" # timeout=10
Checking out Revision 163cbc7c752b6ee13766e5f33acce17ba7402856 (refs/remotes/origin/master)
 > C:/Program Files/Git/cmd/git.exe config core.sparsecheckout # timeout=10
 > C:/Program Files/Git/cmd/git.exe checkout -f 163cbc7c752b6ee13766e5f33acce17ba7402856 # timeout=10
Commit message: "Merge pull request #61 from epics-base/access-security"
 > C:/Program Files/Git/cmd/git.exe rev-list --no-walk 3d888491c114cd313bdb28c4aabf85a6054249e7 # timeout=10
[3.15-example-win64] $ cmd /c call C:\Users\jenkins\AppData\Local\Temp\jenkins5561684391628615836.bat
C:\jenkins\win64-2\workspace\3.15-example-win64>SET TA=win64
C:\jenkins\win64-2\workspace\3.15-example-win64>SET BV=3.15.6
C:\jenkins\win64-2\workspace\3.15-example-win64>SET MO=all
C:\jenkins\win64-2\workspace\3.15-example-win64>REM SET MO=-j4 -O --no-print-directory
C:\jenkins\win64-2\workspace\3.15-example-win64>SET WS=C:/Jenkins/win64-2/workspace
C:\jenkins\win64-2\workspace\3.15-example-win64>echo # RELEASE.local for jenkins-3.15-example-win64-238 1>configure/RELEASE.local
C:\jenkins\win64-2\workspace\3.15-example-win64>echo PVDATABASE = C:/Jenkins/win64-2/workspace/3.15-pvDatabase-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\3.15-example-win64>echo PVACLIENT = C:/Jenkins/win64-2/workspace/3.15-pvaClient-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\3.15-example-win64>echo PVA2PVA = C:/Jenkins/win64-2/workspace/3.15-pva2pva-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\3.15-example-win64>echo PVACCESS = C:/Jenkins/win64-2/workspace/3.15-pvAccess-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\3.15-example-win64>echo NORMATIVE = C:/Jenkins/win64-2/workspace/3.15-normativeTypes-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\3.15-example-win64>echo PVDATA = C:/Jenkins/win64-2/workspace/3.15-pvData-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\3.15-example-win64>echo EPICS_BASE = C:/epics/base-3.15.6 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\3.15-example-win64>make all
make -C ./configure install
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/configure'>
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/configure/O.windows-x64'>
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/convertRelease.pl checkRelease
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/configure/O.windows-x64'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/configure'>
make -C ./database install
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/database'>
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/database/configure'>
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/database/configure/O.windows-x64'>
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/database/configure/O.windows-x64'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/database/configure'>
make -C ./src install
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/database/src'>
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/database/src/O.windows-x64'>
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m exampleHelloRPCClient.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvDatabase-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvaClient-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pva2pva-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-normativeTypes-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        exampleHelloRPCClient.obj ../exampleHelloRPCClient.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m exampleDatabaseMain.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvDatabase-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvaClient-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pva2pva-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-normativeTypes-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        exampleDatabaseMain.obj ../exampleDatabaseMain.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m exampleSoftRecordRegister.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvDatabase-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvaClient-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pva2pva-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-normativeTypes-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        exampleSoftRecordRegister.obj ../exampleSoftRecordRegister.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m exampleDatabaseRegister.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvDatabase-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvaClient-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pva2pva-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-normativeTypes-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        exampleDatabaseRegister.obj ../exampleDatabaseRegister.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m exampleDatabase.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvDatabase-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvaClient-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pva2pva-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-normativeTypes-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        exampleDatabase.obj ../exampleDatabase.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m exampleHelloRPCRecord.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvDatabase-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvaClient-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pva2pva-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-normativeTypes-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        exampleHelloRPCRecord.obj ../exampleHelloRPCRecord.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m exampleSoftRecord.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvDatabase-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvaClient-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pva2pva-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-normativeTypes-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        exampleSoftRecord.obj ../exampleSoftRecord.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m exampleHelloRecord.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvDatabase-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvaClient-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pva2pva-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-normativeTypes-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        exampleHelloRecord.obj ../exampleHelloRecord.cpp
"Installing dbd file ../../dbd/exampleDatabaseRegister.dbd"
mkdir ../../dbd
"Installing dbd file ../../dbd/exampleSoftRecordRegister.dbd"
"Installing generic include file ../../include/pv/exampleHelloRecord.h"
mkdir ../../include
mkdir ../../include/pv
"Installing generic include file ../../include/pv/exampleHelloRPCRecord.h"
"Installing generic include file ../../include/pv/exampleSoftRecord.h"
"Installing generic include file ../../include/pv/exampleDatabase.h"
make[3]: *** No rule to make target '../../lib/windows-x64/pvDatabase.lib', needed by 'exampleDatabase.dll'.  Stop.
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/database/src/O.windows-x64'>
make[2]: *** [C:/epics/base-3.15.6/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/database/src'>
make[1]: *** [C:/epics/base-3.15.6/configure/RULES_DIRS:84: src.install] Error 2
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/3.15-example-win64/ws/database'>
make: *** [C:/epics/base-3.15.6/configure/RULES_DIRS:84: database.install] Error 2
C:\jenkins\win64-2\workspace\3.15-example-win64>exit 2
Build step 'Execute Windows batch command' marked build as failure
Jenkins build is back to normal : 3.15-example-win64 #239 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-pvDatabase-win64 #886 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-example #715 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-pvDatabase-win64 #899 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : 3.15-example-win64 #239 APS Jenkins via Core-talk
ANJ, 09 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
