2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 541371] Re: assert (ev_que->evque[ev_que->putix] == EVENTQEMPTY) failed in dbEvent.c
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 20 May 2021 01:25:41 -0000
For the two instances reached through event_add_action(), I wonder if
this is a use-after-free race with a client which is disconnecting.  Use
of freelibLib could keep this from being detected, or obviously
crashing.  Perhaps related to asComputeAsg(), and thus
casAccessRightsCB(), which is one  way in which RSRV clients can
interact with each other directly.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/541371
Title:
  dbEvent.c
Status in EPICS Base:
  Incomplete
Bug description:
  2009-06-04 10:00   iocsrvid2>
  CAS-client: A call to "assert (ev_que->evque[ev_que->putix] == EVENTQEMPTY)" failed in ../dbEvent.c at 683 Current time THU JUN 04 2009 10:08:33.581404952.
  EPICS Release EPICS R3.14.10-asd1 $R3-14-10$ $2008/10/27 19:39:04$.
  Please E-mail this message and the output from "tt (0x13144d0)"
  to the author or to tech-talk at aps.anl.gov Thread CAS-client (0x13144d0) suspended
  causing all the network buffers to get used up and all network-related
  activities to die, e.g:
  callbackRequest: cbHigh ring buffer full
  NTPTimeSync: NTP requests failing - S_sntpcLib_TIMEOUT DB CA Link Exception: "Virtual circuit unresponsive", context "164.54.2.121:5064"
  save_restore:do_seq - '/iocinfo/saverestore/iocsrvid2/ srvid2AutosaveV3.sav' not found.  Writing a new one. [090604-101331]
  ../online_notify.c: CA beacon (send to "164.54.3.255:5065") error was "S_errno_ENOBUFS"
  iocsrvid2> tt 0x13144d0
  133288 vxTaskEntry    +68 : 19290c0 ()
  1929118 epicsThreadOnceOsd+168: camsgtask ()
  1864ab4 camsgtask      +260: camessage ()
  1868ba8 camessage      +2f0: 1867bb8 ()
  1867e3c rsrvFreePutNotify+880: db_post_single_event () 188629c db_post_single_event+38 : 1885f84 () 1886080 db_post_extra_labor+194: epicsAssert ()
  1928234 epicsAssert    +f8 : epicsThreadSuspendSelf ()
  1929274 epicsThreadSuspendSelf+14 : taskSuspend () value = 0 = 0x0
  This is a PowerPC running vxWorks 5.5.2 and Base R3.14.10.  The IOC
  had to be rebooted.  This is the second or third time we've seen
  ENOBUFS recently, although the engineers didn't see (look for)
  assertion failure before this.
  Original Mantis Bug: mantis-342
      http://www.aps.anl.gov/epics/mantis/view_bug_page.php?f_id=342
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/541371/+subscriptions
Prev: [Bug 541371] Re: assert (ev_que->evque[ev_que->putix] == EVENTQEMPTY) failed in dbEvent.c mdavidsaver via Core-talk
Next: [Bug 541371] Re: assert (ev_que->evque[ev_que->putix] == EVENTQEMPTY) failed in dbEvent.c mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [Bug 541371] Re: assert (ev_que->evque[ev_que->putix] == EVENTQEMPTY) failed in dbEvent.c Hu, Yong via Core-talk
ANJ, 20 May 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
