2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Deadlock on VxWorks 6.7
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>
Cc: "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Wed, 2 Jun 2021 08:45:25 -0500
On 6/2/21 2:23 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> Hi,
> When I use EPICS 7.0.5.1 or 7.0.4.1 on mv mv5100 running VxWorks 6.7, I see shortly after booting:
> 0x132f380 (timerQueue): epicsSpinLock(0x1fda0b79): Deadlock.
> Recursive lock, missed unlock or block when locked.Thread timerQueue (0x132f380) can't proceed, suspending.
> Any idea?
Not immediately, though I'm more familiar with the RTEMS side.
I don't see any recursive call in the stack trace you provided.
Is it possible that the behavior of taskLock() has changed wrt. disabling interrupts?
> Why spinlocks on a single core CPU machine?
The RTEMS and vxWorks implementations don't actually spin.
https://github.com/epics-base/epics-base/blob/b777233efb06fa4e988c4f0738b0270dd3d095a3/modules/libcom/src/osi/os/vxWorks/osdSpin.c#L64-L86
AW: Deadlock on VxWorks 6.7 Zimoch Dirk (PSI) via Core-talk
Prev: Re: Deadlock on VxWorks 6.7 Mark Rivers via Core-talk
Next: AW: Deadlock on VxWorks 6.7 Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: AW: Deadlock on VxWorks 6.7 Zimoch Dirk (PSI) via Core-talk
ANJ, 02 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
