2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-7 #352
From: Jenkins EPICS PSI via Core-talk <core-talk at aps.anl.gov>
To: <dirk.zimoch at psi.ch>, <core-talk at aps.anl.gov>
Date: Sat, 5 Jun 2021 20:29:18 +0200
See <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/352/display/redirect?page=changes>
Changes:
[bchandler] Extract compiler pre-defined macros as Make variables
[bchandler] Enable Epics for RTEMS5 (posix)
[bchandler] RTEMS: auto-detect OS_API
[bchandler] ci: RTEMS update
[bchandler] epicsNtp: avoid deprecated/non-standard bzero()
[bchandler] WIP: fix missing bits needed by osiNTPTime.c
[bchandler] RTEMS5: redirect to serial via runtime
[bchandler] RTEMS: fix NIC for testing w/ RTEMS5
[bchandler] re-drop RTEMS osdMessageQueue
[bchandler] rtems5: fix linking of dependent modules, need -lCom after -lrtemsCom
[bchandler] rtems5: correct ifreq_size()
[bchandler] Install toolchain data into cfg/ directory
[bchandler] Set GNU_TARGET automatically
[bchandler] Explain the RTEMS config variables
[bchandler] Move HAVE_SOCKADDR_SA_LEN=1 for darwin targets
[bchandler] Add RTEMS-pc686-qemu for use on RTEMS 5.x
[bchandler] Clean up CONFIG.Common.RTEMS
[bchandler] Enable RTEMS testing in modules/database/test/std/link
[bchandler] Set RTEMS_TARGET for Travis builds
[bchandler] Simplify RTEMS OP_SYS_CFLAGS settings
[bchandler] restore $(API_CPPFLAGS)
[bchandler] Prepared RTEMS 4.10 posix with network
[bchandler] Fixed stupid typo in CONFIG.Common.RTEMS
[bchandler] cleanup netconfig
[bchandler] MQ name creation changed
[bchandler] changed pvAccess url, save adaption to old network stack
[bchandler] Link pvData module to mdavidsaver
[bchandler] Add LEGACY_STACK_SUPPORT and telnet client
[bchandler] Add posix cpp flags to RTEMS config
[bchandler] Cosmetics and some typos
[bchandler] Add dhcp option cmdline (129)
[bchandler] Remove redundant CPU_FLAGS use.
[bchandler] remove missing rtems_bsd_set_vprintf_handler
[bchandler] Fixes for CI mechanics
[bchandler] Remove tab from ci-scripts-build.yml
[bchandler] Reintroduce API_CPPFLAGS argument to fix Windows builds
[bchandler] Make pvData and pvAccess submodules use epics-base
[bchandler] Fix compile errors after rebasing changes for RTEMS5
[bchandler] Make RTEMS-pc386-qemu use RTEMS-pc386 rather than pc686
[bchandler] Make sure the definition of IPPORT_USERRESERVED is defined
[bchandler] Switch to rtl8139 network interface for RTEMS tests
[bchandler] re-remove osdMessageQueue.c from RTEMS-kernel
[bchandler] Remove define of bzero to use memset
[bchandler] Remove prototype definition of select() from osdSock.h
[bchandler] Fix merge issues with src/tools/makeTestfile.pl
[bchandler] Restore CROSS_COMPILER_TARGET_ARCHS initialization in CONFIG_SITE
[bchandler] Fix license comment in epicsNtp.c and .h
[bchandler] Remove FHI specific information from NTP and bootp variable init
[bchandler] Remove local def of VERSION_INIT in favor of one from epicsVersion.h
[bchandler] Don't use or include mlock() on RTEMS
[bchandler] Include osdTime using compiler include path
[bchandler] Enable tests for RTEMS5
[bchandler] RTEMS DHCP: Use safer versions of string functions
[bchandler] squash me
[bchandler] Clean up a couple warnings in RTEMS code
[bchandler] Change telnetd configuration to use defaults
[bchandler] rtems dhcp: remove strncmp on environment vars in favor of strcmp
[bchandler] Increase DHCP timeouts
[bchandler] Add commented code that starts an RTEMS shell, useful for debugging
[bchandler] osiSockTest: Give a clearer error message if sendto() fails
[bchandler] makeTestfile: revert to e1000
[bchandler] osiSockTest: use strerror rather than strerror_r
[bchandler] Fix merge error in osiSockTest.c
[bchandler] Enable initializing the filesystem in RTEMS5
[bchandler] Remove unused variable
[bchandler] RTEMS e500: use mkimage from RTEMS rathr than system one
[bchandler] Only write out dhcpcd.conf if it doesn't exist.
[bchandler] epicPosicMutexInit: avoid calling with 0 which is platform dependent
[bchandler] Allow RTEMS to use normal dlopen() symbols
[bchandler] Remove unused DHAVE_SOCKADDR_SA_LEN
[bchandler] RTEMS ne2kpci: clean up when its included
[bchandler] rtems_config: Guard using __RTEMS_MAJOR__ rather than net stack
[bchandler] rtems_config: Fix typo in #if statement
[bchandler] rtems_config: Change config options based on BSP name
[anj] Fixes for RTEMS-uC5282 with legacy stack
[mdavidsaver] RTEMS: Drop dependency on bspExt
[mdavidsaver] ci: update toolchain and test more targets
[bchandler] Disable building mvme2100, mvme167, uC8252 for RTEMS5
[bchandler] Update release notes and documentation for RTEMS5
[bchandler] Update release note about RTEMS 5 support
[anj] Fix implicit declaration of memcpy()
[anj] RTEMS-uC5282 BSP provides bspExtMemProbe()
[anj] Fix old comments
[anj] Adjust Max FDs to match newlib
[anj] Drop pragma message in rtems_init
[anj] Attempt to fix GHA config file
[anj] Fixed indentation in GHA config file
[anj] Update Release Notes for RTEMS-5 port
[anj] Fix warning when not using CLOEXEC
[anj] Add missing dependency
[anj] Rename RTEMS-kernel to RTEMS-score (OS_API)
[anj] Drop macOS PowerPC host-arch's
[anj] Drop macOS i386 ARCH_CLASS, add arm64
[anj] Remove aix-ppc files from extensions template
[anj] Remove linux-cris target files
[anj] Drop RTEMS-at91rm9200ek and RTEMS-psim targets
[anj] Drop CPU-specific linux-[3456]86 cross-targets
[anj] Obsolete Extensions template files
[anj] Drop RTEMS-gen68360, RTEMS-mcp750 and RTEMS-mvme167
[anj] Document removals
[anj] Oops, fix path
Started by an SCM change
Building in workspace <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Deferred wipeout is used...
[WS-CLEANUP] Done
Cloning the remote Git repository
Cloning repository https://git.launchpad.net/epics-base
 > git init <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/> # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
 > git --version # timeout=10
 > git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
 > git config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
 > git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git rev-parse origin/7.0^{commit} # timeout=10
Checking out Revision c98e5085c3e9b765bc5425cfa1ec103bb6c1c451 (origin/7.0)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f c98e5085c3e9b765bc5425cfa1ec103bb6c1c451
Commit message: "Merge branch 'drop-obselete-archs' into 7.0"
 > git rev-list --no-walk b777233efb06fa4e988c4f0738b0270dd3d095a3 # timeout=10
 > git remote # timeout=10
 > git submodule init # timeout=10
 > git submodule sync # timeout=10
 > git config --get remote.origin.url # timeout=10
 > git config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10
 > git config --get submodule.modules/pvData.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
 > git submodule update --init --recursive --remote modules/pvData
 > git config --get submodule.modules/pvAccess.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10
 > git submodule update --init --recursive --remote modules/pvAccess
 > git config --get submodule.modules/normativeTypes.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10
 > git submodule update --init --recursive --remote modules/normativeTypes
 > git config --get submodule.modules/pvaClient.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10
 > git submodule update --init --recursive --remote modules/pvaClient
 > git config --get submodule.modules/pvDatabase.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
 > git submodule update --init --recursive --remote modules/pvDatabase
 > git config --get submodule.modules/pva2pva.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
 > git submodule update --init --recursive --remote modules/pva2pva
 > git config --get submodule..ci.url # timeout=10
 > git config -f .gitmodules --get submodule..ci.path # timeout=10
 > git submodule update --init --recursive --remote .ci
[EPICS-7] $ /bin/sh -xe /tmp/jenkins8443949868401261491.sh
+ tar xfz /net/sls-hafs/export/exchange/home/zimoch/epics/PSIconfig.tgz
+ patch -p1
patching file configure/os/CONFIG_SITE.Common.vxWorksCommon
patching file configure/os/CONFIG_SITE.linux-x86.Common
Hunk #1 FAILED at 7.
1 out of 1 hunk FAILED -- saving rejects to file configure/os/CONFIG_SITE.linux-x86.Common.rej
patching file configure/os/CONFIG_SITE.linux-x86_64.Common
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: EPICS-7 #353 Jenkins EPICS PSI via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-334 AppVeyor via Core-talk
Next: RE: EPICS Base 3.15.8: Name resolution requests directed to non-existing hosts block CA Server Freddie Akeroyd - STFC UKRI via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Build failed in Jenkins: EPICS-7 #353 Jenkins EPICS PSI via Core-talk
ANJ, 10 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
