2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Bug in vxWorks implementation and/or usage of epicsAtomicCmpAndSwapIntT
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Tue, 8 Jun 2021 15:26:10 +0000
The usage of epicsAtomicCmpAndSwapIntT for example in callback.c suggests that the function should return the previous
value. But the VxWorks implementation uses vxCas which is documented as returning "TRUE if the write actually occurs,
FALSE otherwise." (at least in VxWorks 6.7).
Comparing this with the gcc documentation:
bool __sync_bool_compare_and_swap (type *ptr, type oldval type newval, ...)
type __sync_val_compare_and_swap (type *ptr, type oldval type newval, ...)
These builtins perform an atomic compare and swap.  That is, if the current value of *ptr is oldval, then write newval
into *ptr.
The “bool” version returns true if the comparison is successful and newval was written.
The “val” version returns the contents of *ptr before the operation.
So it seems epicsAtomicCmpAndSwapIntT is expected to behave like __sync_val_compare_and_swap (and that is what is
actually implemented in libcom/src/osi/compiler/gcc/epicsAtomicCD.h) but vxCas as used in
libcom/src/osi/os/vxWorks/epicsAtomicOSD.h actually behaves like __sync_bool_compare_and_swap.
Dirk
Prev: Re: Deadlock on VxWorks 6.7 Zimoch Dirk (PSI) via Core-talk
Next: softiIoc and softIocPVA incomplete on VxWorks (and others?) Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Tests on RTEMS-pc686-qemu Chandler, Brendan via Core-talk
ANJ, 09 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
