2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Problem building ezcaIDL on Windows
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: "'Johnson, Andrew N.'" <anj at anl.gov>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Fri, 11 Jun 2021 20:03:21 +0000
The names are already decorated with epicsShareFunc and epicsShareAPI.
It exports the symbols OK for these cases:
-          windows-x64 architecture
-          windows-x64-static architecture if the Makefile contains SHARED_LIBRARIES=YES, whether I use LIBRARY_HOST or LOADABLE_LIBRARY_HOST.
Sent: Friday, June 11, 2021 2:33 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Subject: Re: Problem building ezcaIDL on Windows
Hi Mark,
On Jun 11, 2021, at 2:17 PM, Mark Rivers <rivers at cars.uchicago.edu> wrote:
If the Makefile contains these lines then it builds the DLL correctly on windows-x64-static.  dumpbin /exports shows the correct exported symbols.
LIBRARY_HOST = ezcaIDL
If the Makefile contains these lines then it builds the DLL, but the DLL does not export any symbols.
#SHARED_LIBRARIES=YES
#LIBRARY_HOST = ezcaIDL
LOADABLE_LIBRARY_HOST = ezcaIDL
H:\epics\extensions_new\src\ezcaIDL>dumpbin /exports ..\..\bin\windows-x64-static\ezcaIDL.dll
Microsoft (R) COFF/PE Dumper Version 14.00.24215.1
Copyright (C) Microsoft Corporation.  All rights reserved.
Dump of file ..\..\bin\windows-x64-static\ezcaIDL.dll
File Type: DLL
  Summary
       15000 .data
        1000 .gfids
        8000 .pdata
       2C000 .rdata
        2000 .reloc
       74000 .text
        1000 .tls
My guess is that if you restored the .def file(s) that might fix it – don't they provide the linker with a list of symbols to export? The other solution would be to decorate all the symbols that need to be exported inside the source code, but that’s going to take more work.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Problem building ezcaIDL on Windows Ralph Lange via Core-talk
Problem building ezcaIDL on Windows Mark Rivers via Core-talk
RE: Problem building ezcaIDL on Windows Mark Rivers via Core-talk
Re: Problem building ezcaIDL on Windows Michael Davidsaver via Core-talk
Re: Problem building ezcaIDL on Windows Johnson, Andrew N. via Core-talk
Prev: Re: Problem building ezcaIDL on Windows Johnson, Andrew N. via Core-talk
Next: Re: Problem building ezcaIDL on Windows Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
ANJ, 12 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
