2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1932118] [NEW] Bug in vxWorks epicsAtomicCmpAndSwapIntT
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 16 Jun 2021 06:58:24 -0000
Public bug reported:
The usage of epicsAtomicCmpAndSwapIntT() in callback.c suggests that the
function should return the previous value. But the VxWorks
implementation uses vxCas() which is documented as returning "TRUE if
the write actually occurs, FALSE otherwise."
vxAtomicLib.html:
vxCas( )
NAME
    vxCas( ) - atomically compare-and-swap the contents of a memory location
SYNOPSIS
    BOOL vxCas
        atomic_t *  target,
        atomicVal_t oldValue,
        atomicVal_t newValue
DESCRIPTION
    This routine performs an atomic compare-and-swap; testing that *target contains oldValue, and if it does, setting the value of *target to newValue.
RETURNS
    TRUE if the swap is actually executed, FALSE otherwise.
Comparing this with the gcc documentation:
bool __sync_bool_compare_and_swap (type *ptr, type oldval type newval, ...)
type __sync_val_compare_and_swap (type *ptr, type oldval type newval, ...)
These builtins perform an atomic compare and swap.  That is, if the
current value of *ptr is oldval, then write newval into *ptr.
The “bool” version returns true if the comparison is successful and newval was written.
The “val” version returns the contents of *ptr before the operation.
That means epicsAtomicCmpAndSwapIntT() behaves behaves like __sync_bool_compare_and_swap(). Simply casting the return value from BOOL to the type of oldVal does not change that.
But the usage implies an expected bahavior like
__sync_val_compare_and_swap (), wich is used in the gcc implementation
of epicsAtomicCmpAndSwapIntT().
This bugs prevents the callback threads from being started in vxWorks 6.7, maybe more or all vxWorks 6 versions.
** Affects: epics-base
     Importance: Undecided
         Status: New
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1932118
Title:
Status in EPICS Base:
  New
Bug description:
  the function should return the previous value. But the VxWorks
  vxAtomicLib.html:
  vxCas( )
  NAME
  SYNOPSIS
      BOOL vxCas
          atomic_t *  target,
  DESCRIPTION
  RETURNS
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1932118/+subscriptions
[Bug 1932118] Re: Bug in vxWorks epicsAtomicCmpAndSwapIntT Dirk Zimoch via Core-talk
[Bug 1932118] Re: Bug in vxWorks epicsAtomicCmpAndSwapIntT Andrew Johnson via Core-talk
[Bug 1932118] Re: Bug in vxWorks epicsAtomicCmpAndSwapIntT mdavidsaver via Core-talk
Prev: Build completed: epics-base base-integration-709 AppVeyor via Core-talk
Next: [Bug 1932120] [NEW] callbackRequest potentially accesses uninitialized memory Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: [Bug 1932118] Re: Bug in vxWorks epicsAtomicCmpAndSwapIntT Dirk Zimoch via Core-talk
ANJ, 03 Jul 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
