2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1932120] Re: callbackRequest potentially accesses uninitialized memory
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 16 Jun 2021 07:21:19 -0000
** Description changed:
  If epicsAtomicCmpAndSwapIntT() in callbackInit() fails for some reason
  (e.g. because of bug #1932118), the callback queues never get
- initialized (and callback threads never get started). Nevertheless,
- callbackRequest() will use these uninitialized queues (and an
- uninitialized event semaphore) without checking, resulting in strange
- message from a spinLock in the uninitialized queue:
+ initialized (and callback threads never get started) and the following
+ warning is printed during iocInit:
+ Warning: callbackInit called again before callbackCleanup
+ Nevertheless,  callbackRequest() will use these uninitialized queues
+ (and an uninitialized event semaphore) without checking, resulting in
+ strange message from a spinLock in the uninitialized queue:
  0x132f380 (timerQueue): epicsSpinLock(0x1fda0b79): Deadlock.
  Recursive lock, missed unlock or block when locked.Thread timerQueue (0x132f380) can't proceed, suspending.
  A patch is attached.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1932120
Title:
Status in EPICS Base:
  New
Bug description:
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1932120/+subscriptions
[Bug 1932120] [NEW] callbackRequest potentially accesses uninitialized memory Dirk Zimoch via Core-talk
Prev: [Bug 1932118] Re: Bug in vxWorks epicsAtomicCmpAndSwapIntT Dirk Zimoch via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-339 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1932120] [NEW] callbackRequest potentially accesses uninitialized memory Dirk Zimoch via Core-talk
Next: [Bug 1932120] Re: callbackRequest potentially accesses uninitialized memory Andrew Johnson via Core-talk
ANJ, 17 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
