2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: PCAS fails to build with latest epics base
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Freddie Akeroyd - STFC UKRI <freddie.akeroyd at stfc.ac.uk>
Cc: "EPICS core-talk \(core-talk at aps.anl.gov\)" <core-talk at aps.anl.gov>
Date: Thu, 24 Jun 2021 17:11:37 -0700
On 6/24/21 5:05 PM, Freddie Akeroyd - STFC UKRI via Core-talk wrote:
> Hi,
> I was just trying a recent EPICS base master with our build tree and had an issue compiling the PCAS module. PCAS includes just <caProto.h> and this file then includes <osdSock.h> and fails to compile as LIBCOM_API is not defined. There are several ways to fix this, I wasn’t sure which was preferred:
> ·         caProto.h could include osiSock.h rather than osdSock.h
I think this is the right solution.
From a quick look, I see two other which needs fixing as well.
> $ grep -R 'include.*osd' include
> include/os/Linux/epicsMMIODef.h:#include <osdSock.h>
> include/os/RTEMS/epicsMMIODef.h:#include <osdSock.h>
> ·         caProto.h could include libComAPI.h before osdSock.h
> Regards,
> Freddie
> This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
RE: PCAS fails to build with latest epics base Freddie Akeroyd - STFC UKRI via Core-talk
Prev: PCAS fails to build with latest epics base Freddie Akeroyd - STFC UKRI via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-348 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE: PCAS fails to build with latest epics base Freddie Akeroyd - STFC UKRI via Core-talk
ANJ, 25 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
