2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1722530] Re: Add userTag to epicsTimeStamp
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 04 Jul 2021 03:31:15 -0000
** Changed in: epics-base
    Milestone: None => 7.0.6
       Status: Triaged => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1722530
Title:
Status in EPICS Base:
  Fix Released
Bug description:
  See core-talk thread at http://www.aps.anl.gov/epics/core-
  talk/2017/msg00538.php
  Needs conclusion on how the userTag should be defined (32/64,
  signed/unsigned).
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1722530/+subscriptions
Prev: [Bug 788230] Re: Support LP64 data model on vxWorks 6.9 Andrew Johnson via Core-talk
Next: [Bug 1934169] Re: initHookName out of sync Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: [Bug 1587610] Re: Base does not build against RTEMS >=4.11 Andrew Johnson via Core-talk
ANJ, 03 Jul 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
