2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1940283] Re: Misleading Error: Invalid character '"'
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 17 Aug 2021 15:54:54 -0000
Why? Because dbLex.l has bugs in the JSON string lexing patterns.
Congratulations, you're the first person to have noticed since JSON
support was introduced to the database!
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1940283
Title:
Status in EPICS Base:
  New
Bug description:
  When using a tab character in a field, EPICS 7 prints a misleading
  error message, not hinting at the tab but at the closing(?) quote.
  Example 1:  field(DESC,  "a	b")
  Example 2:  info(TAB,  "a	b")
   at or before """ in path "."  file "..." line ...
  BTW: Is there a reason why I cannot use a tab in my (info) fields?
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1940283/+subscriptions
[Bug 1940283] [NEW] Misleading Error: Invalid character '"' Dirk Zimoch via Core-talk
Prev: Build failed: epics-base base-integration-748 AppVeyor via Core-talk
Next: [Bug 1940283] Re: Misleading Error: Invalid character '"' mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1940283] Re: Misleading Error: Invalid character '"' Dirk Zimoch via Core-talk
ANJ, 17 Aug 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
