2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-7 #376
From: Jenkins EPICS PSI via Core-talk <core-talk at aps.anl.gov>
To: <dirk.zimoch at psi.ch>, <core-talk at aps.anl.gov>
Date: Sun, 29 Aug 2021 20:29:41 +0200
See <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/376/display/redirect?page=changes>
Changes:
[mdavidsaver] Fix bugs in dbRecordNameValidate()
[mdavidsaver] Fix spelling in comments
[mdavidsaver] Fix long string handling for CALC$
[mdavidsaver] long CALC$ regressTest
[mdavidsaver] Fix DB link to DBF_MENU as DBF_STRING
[mdavidsaver] test regressLinkSevr
[...truncated 237.78 KB...]
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsEvent.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsTime.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsMessageQueue.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsMath.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/epicsAtomicOSD.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsGeneralTime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/osiClockTime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdSock.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdSockAddrReuse.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdSockUnsentCount.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/osiSock.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/systemCallIntMech.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdAssert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdFindSymbol.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdInterrupt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdPoolStatus.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdSignal.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdEnv.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE         -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsReadline.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/epicsTempFile.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsStdio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdStdio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdThread.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdThreadExtra.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdThreadHooks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdMutex.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdSpin.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdEvent.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdTime.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdMonotonic.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdProcess.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdNetIntf.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdMessageQueue.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdgetexec.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/devLibVME.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/devLibVMEOSD.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsStackTrace.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdBackTrace.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdFindAddr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../pool/poolJob.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../pool/threadPool.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ring/epicsRingPointer.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ring/epicsRingBytes.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../taskwd/taskwd.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/epicsTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timerQueue.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timerQueueActive.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timerQueueActiveMgr.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall     -std=c++11        -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timerQueuePassive.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_alloc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_buf.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_encode.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_gen.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_lex.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing -DBUILDING_libCom_API   -O3   -Wall -Werror-implicit-function-declaration            -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_parser.c
/usr/bin/ar -rc    libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o
/usr/bin/ranlib libCom.a
/usr/bin/g++ -o libCom.so.3.20.1 -shared -fPIC -Wl,-hlibCom.so.3.20.1 -L<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/lib/RHEL7-x86_64> -Wl,-rpath,<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/lib/RHEL7-x86_64>           -rdynamic -m64         asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o       -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../../lib/RHEL7-x86_64/libCom.so.3.20.1
mkdir ../../../../lib/RHEL7-x86_64
ln -s libCom.so.3.20.1 ../../../../lib/RHEL7-x86_64/libCom.so
Installing library ../../../../lib/RHEL7-x86_64/libCom.a
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux  -fno-strict-aliasing    -O3   -Wall -Werror-implicit-function-declaration            -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../log/iocLogServer.c
/usr/bin/g++ -o iocLogServer  -L<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/lib/RHEL7-x86_64> -Wl,-rpath,<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/lib/RHEL7-x86_64>           -rdynamic -m64         iocLogServer.o    -lCom
Installing created executable ../../../../bin/RHEL7-x86_64/iocLogServer
make[4]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src/O.RHEL7-x86_64'>
make -C O.T2-ppc604 -f ../Makefile TOP=../../../.. \
    T_A=T2-ppc604 install
make[4]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src/O.T2-ppc604'>
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/expandVars.pl> -t ../../../.. -D INSTALL_BIN=<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/T2-ppc604>  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="20"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m strtoull.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h strtoull.o ../osi/os/vxWorks/strtoull.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m strtoll.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h strtoll.o ../osi/os/vxWorks/strtoll.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m logMsgToErrlog.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h logMsgToErrlog.o ../osi/os/vxWorks/logMsgToErrlog.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m veclist.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h veclist.o ../osi/os/vxWorks/veclist.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsDynLink.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsDynLink.o ../osi/os/vxWorks/epicsDynLink.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m atReboot.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h atReboot.o ../osi/os/vxWorks/atReboot.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m tz2timezone.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h tz2timezone.o ../osi/os/vxWorks/tz2timezone.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osiNTPTime.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osiNTPTime.o ../osi/osiNTPTime.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m yajl_parser.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h yajl_parser.o ../yajl/yajl_parser.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m yajl_lex.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h yajl_lex.o ../yajl/yajl_lex.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m yajl_gen.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h yajl_gen.o ../yajl/yajl_gen.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m yajl_encode.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h yajl_encode.o ../yajl/yajl_encode.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m yajl_buf.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h yajl_buf.o ../yajl/yajl_buf.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m yajl_alloc.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h yajl_alloc.o ../yajl/yajl_alloc.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m yajl.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h yajl.o ../yajl/yajl.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m timerQueuePassive.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h timerQueuePassive.o ../timer/timerQueuePassive.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m timerQueueActiveMgr.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h timerQueueActiveMgr.o ../timer/timerQueueActiveMgr.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m timerQueueActive.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h timerQueueActive.o ../timer/timerQueueActive.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m timerQueue.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h timerQueue.o ../timer/timerQueue.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m timer.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h timer.o ../timer/timer.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsTimer.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsTimer.o ../timer/epicsTimer.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m taskwd.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h taskwd.o ../taskwd/taskwd.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsRingBytes.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsRingBytes.o ../ring/epicsRingBytes.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsRingPointer.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsRingPointer.o ../ring/epicsRingPointer.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m threadPool.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h threadPool.o ../pool/threadPool.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m poolJob.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h poolJob.o ../pool/poolJob.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdFindAddr.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdFindAddr.o ../osi/os/default/osdFindAddr.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdBackTrace.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdBackTrace.o ../osi/os/default/osdBackTrace.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsStackTrace.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsStackTrace.o ../osi/epicsStackTrace.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m devLibVMEOSD.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h devLibVMEOSD.o ../osi/os/vxWorks/devLibVMEOSD.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m devLibVME.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h devLibVME.o ../osi/devLibVME.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdgetexec.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdgetexec.o ../osi/os/default/osdgetexec.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdMessageQueue.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdMessageQueue.o ../osi/os/vxWorks/osdMessageQueue.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdNetIntf.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdNetIntf.o ../osi/os/default/osdNetIntf.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdProcess.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdProcess.o ../osi/os/vxWorks/osdProcess.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdMonotonic.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdMonotonic.o ../osi/os/vxWorks/osdMonotonic.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdTime.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdTime.o ../osi/os/vxWorks/osdTime.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdEvent.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdEvent.o ../osi/os/vxWorks/osdEvent.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdSpin.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdSpin.o ../osi/os/vxWorks/osdSpin.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdMutex.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdMutex.o ../osi/os/vxWorks/osdMutex.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdThreadHooks.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdThreadHooks.o ../osi/os/default/osdThreadHooks.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdThreadExtra.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdThreadExtra.o ../osi/os/vxWorks/osdThreadExtra.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdThread.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdThread.o ../osi/os/vxWorks/osdThread.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdStdio.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdStdio.o ../osi/os/vxWorks/osdStdio.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsStdio.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsStdio.o ../osi/epicsStdio.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsTempFile.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsTempFile.o ../osi/os/posix/epicsTempFile.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsReadline.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsReadline.o ../osi/epicsReadline.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdEnv.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdEnv.o ../osi/os/vxWorks/osdEnv.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdSignal.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdSignal.o ../osi/os/vxWorks/osdSignal.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdPoolStatus.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdPoolStatus.o ../osi/os/vxWorks/osdPoolStatus.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdInterrupt.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdInterrupt.o ../osi/os/vxWorks/osdInterrupt.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdFindSymbol.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdFindSymbol.o ../osi/os/vxWorks/osdFindSymbol.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdAssert.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdAssert.o ../osi/os/default/osdAssert.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsSocketConvertErrnoToString.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsSocketConvertErrnoToString.o ../osi/os/default/epicsSocketConvertErrnoToString.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m systemCallIntMech.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h systemCallIntMech.o ../osi/os/posix/systemCallIntMech.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osiSock.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osiSock.o ../osi/osiSock.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdSockUnsentCount.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdSockUnsentCount.o ../osi/os/default/osdSockUnsentCount.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdSockAddrReuse.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdSockAddrReuse.o ../osi/os/default/osdSockAddrReuse.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osdSock.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osdSock.o ../osi/os/vxWorks/osdSock.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m osiClockTime.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h osiClockTime.o ../osi/osiClockTime.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsGeneralTime.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsGeneralTime.o ../osi/epicsGeneralTime.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsAtomicOSD.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsAtomicOSD.o ../osi/os/vxWorks/epicsAtomicOSD.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsMath.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsMath.o ../osi/epicsMath.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsMessageQueue.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsMessageQueue.o ../osi/epicsMessageQueue.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsTime.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsTime.o ../osi/epicsTime.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsEvent.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsEvent.o ../osi/epicsEvent.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsMutex.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsMutex.o ../osi/epicsMutex.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsThread.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsThread.o ../osi/epicsThread.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsUnitTest.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsUnitTest.o ../misc/epicsUnitTest.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m ipAddrToAsciiAsynchronous.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h ipAddrToAsciiAsynchronous.o ../misc/ipAddrToAsciiAsynchronous.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m truncateFile.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h truncateFile.o ../misc/truncateFile.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsString.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsString.o ../misc/epicsString.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsStdlib.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsStdlib.o ../misc/epicsStdlib.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsExit.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsExit.o ../misc/epicsExit.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsConvert.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsConvert.o ../misc/epicsConvert.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m cantProceed.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h cantProceed.o ../misc/cantProceed.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m adjustment.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h adjustment.o ../misc/adjustment.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m aToIPAddr.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h aToIPAddr.o ../misc/aToIPAddr.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m alarmString.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h alarmString.o ../misc/alarmString.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m macUtil.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h macUtil.o ../macLib/macUtil.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m macEnv.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h macEnv.o ../macLib/macEnv.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m macCore.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h macCore.o ../macLib/macCore.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m logClient.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h logClient.o ../log/logClient.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m iocLog.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h iocLog.o ../log/iocLog.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m libComRegister.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h libComRegister.o ../iocsh/libComRegister.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m registry.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h registry.o ../iocsh/registry.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m initHooks.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h initHooks.o ../iocsh/initHooks.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m iocsh.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h iocsh.o ../iocsh/iocsh.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m gpHashLib.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h gpHashLib.o ../gpHash/gpHashLib.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m freeListLib.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h freeListLib.o ../freeList/freeListLib.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m fdManager.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h fdManager.o ../fdmgr/fdManager.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m fdmgr.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h fdmgr.o ../fdmgr/fdmgr.cpp
perl -CSD ../error/makeStatTbl.pl  ../osi/devLib.h ../osi/epicsTime.h ../as/asLib.h ../misc/epicsStdlib.h ../pool/epicsThreadPool.h ../error/errMdef.h ../../../../modules/database/src/ioc/db/dbAccessDefs.h ../../../../modules/database/src/ioc/dbStatic/dbStaticLib.h
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m errSymTbl.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h errSymTbl.o errSymTbl.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m errSymLib.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h errSymLib.o ../error/errSymLib.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m errlog.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h errlog.o ../error/errlog.c
perl -CSD ../../../../bin/RHEL7-x86_64/bldEnvData.pl  -t T2-ppc604 \
	-c gcc -s vxWorks ../../../../configure
Generating envData.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m envData.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h envData.o envData.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m envSubr.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h envSubr.o ../env/envSubr.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m ellSort.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h ellSort.o ../ellLib/ellSort.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m ellLib.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h ellLib.o ../ellLib/ellLib.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m dbmf.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h dbmf.o ../dbmf/dbmf.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m epicsSingletonMutex.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h epicsSingletonMutex.o ../cxxTemplates/epicsSingletonMutex.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m resourceLib.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h resourceLib.o ../cxxTemplates/resourceLib.cpp
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m cvtFast.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h cvtFast.o ../cvtFast/cvtFast.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m calcPerform.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h calcPerform.o ../calc/calcPerform.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m postfix.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h postfix.o ../calc/postfix.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m bucketLib.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h bucketLib.o ../bucketLib/bucketLib.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m asTrapWrite.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h asTrapWrite.o ../as/asTrapWrite.c
<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/e_flex> -S../../../../include/flex.skel.static -8 -I -oasLib_lex.c ../as/asLib_lex.l
<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/antelope> -basLib  ../as/asLib.y
mv asLib.tab.c asLib.c
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/mkmf.pl>  -m asLib.d -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h asLib.o asLib.c
make[4]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src/O.T2-ppc604'>
make[4]: Entering directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src/O.T2-ppc604'>
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/expandVars.pl> -t ../../../.. -D INSTALL_BIN=<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/bin/T2-ppc604>  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="20"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
Installing generated generic include file ../../../../include/libComVersion.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdSock.h
mkdir ../../../../include/os/vxWorks
Installing OS dependent include file ../../../../include/os/vxWorks/osdInterrupt.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdMutex.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdEvent.h
Installing OS dependent include file ../../../../include/os/vxWorks/epicsMath.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdMessageQueue.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdStrtod.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdPoolStatus.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdThread.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdTime.h
Installing OS dependent include file ../../../../include/os/vxWorks/osiUnistd.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdWireFormat.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdWireConfig.h
Installing OS dependent include file ../../../../include/os/vxWorks/epicsAtomicOSD.h
Installing OS dependent include file ../../../../include/os/vxWorks/epicsGetopt.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdVME.h
Installing OS dependent include file ../../../../include/os/vxWorks/epicsMMIO.h
Installing OS dependent include file ../../../../include/os/vxWorks/epicsMMIODef.h
Installing OS dependent include file ../../../../include/os/vxWorks/camacLib.h
Installing OS dependent include file ../../../../include/os/vxWorks/epicsDynLink.h
Installing OS dependent include file ../../../../include/os/vxWorks/module_types.h
Installing OS dependent include file ../../../../include/os/vxWorks/task_params.h
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h     -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../osi/os/vxWorks/vxComLibrary.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c asLib.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../as/asTrapWrite.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../bucketLib/bucketLib.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../calc/postfix.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../calc/calcPerform.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../cvtFast/cvtFast.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../cxxTemplates/resourceLib.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../cxxTemplates/epicsSingletonMutex.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../dbmf/dbmf.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../ellLib/ellLib.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../ellLib/ellSort.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../env/envSubr.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c envData.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../error/errlog.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../error/errSymLib.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall -Werror-implicit-function-declaration      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c errSymTbl.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/host/x86-linux2/bin/ccppc       -isystem /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h   -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/target/h/vxWorks.h  -DBUILDING_libCom_API   -O0   -Wall      -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin -fno-strict-aliasing  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/afs/psi.ch/project/vxworks/Tornado2.2.1/target/h -c ../fdmgr/fdmgr.cpp
In file included from ../fdmgr/fdManager.h:25,
                 from ../fdmgr/fdmgr.cpp:27:
../osi/epicsTime.h:32: ostream: No such file or directory
make[4]: *** [fdmgr.o] Error 1
make[3]: *** [install.T2-ppc604] Error 2
make[3]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom/src'>
make[2]: *** [src.install] Error 2
make[2]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules/libcom'>
make[1]: *** [libcom.install] Error 2
make[1]: Leaving directory `<http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/modules'>
make: *** [modules.install] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : EPICS-7 #377 Jenkins EPICS PSI via Core-talk
Build failed in Jenkins: EPICS-7 #375 Jenkins EPICS PSI via Core-talk
Prev: epics-7.0 » linux32 - Build # 358 - Still Unstable! APS Jenkins via Core-talk
Next: Build completed: epics-base base-7.0-751 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: EPICS-7 #375 Jenkins EPICS PSI via Core-talk
Next: Jenkins build is back to normal : EPICS-7 #377 Jenkins EPICS PSI via Core-talk
ANJ, 31 Aug 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
