2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1943245] [NEW] epicsStrnEscapedFromRaw may print inclomplete escape sequences
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 10 Sep 2021 10:14:21 -0000
Public bug reported:
When epicsStrnEscapedFromRaw runs out of buffer space in the middle of an escape sequence, it prints incomplete and thus invalid sequences.
For example printing "\xff" (1 byte 0xff) into a buffer that is too short may result in `\`, `\x`, or `\xf`. In particular a stray `\` at the end may be misinterpreted for example when the escaped string itself is printed in quotes and then the outer ending quote gets "escaped".
Instead of printing incomplete sequences it should rather not print the
sequence at all.
** Affects: epics-base
     Importance: Undecided
         Status: New
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1943245
Title:
Status in EPICS Base:
  New
Bug description:
  the sequence at all.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1943245/+subscriptions
Prev: Build failed: pva2pva 1.0.34 AppVeyor via Core-talk
Next: Build failed: pva2pva 1.0.41 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Build failed: pva2pva 1.0.40 AppVeyor via Core-talk
ANJ, 10 Sep 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
