2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: epics-7.0 » mac - Build # 362 - Failure!
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 25 Sep 2021 23:30:46 -0500 (CDT)
Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=mac/362/
This job failed to build.
Started by upstream project "epics-7.0" build number 362
originally caused by:
 Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on mac-1 (mac) in workspace /Users/jenkins/workspace/epics-7.0/OS/mac
The recommended git tool is: NONE
No credentials specified
 > git rev-parse --resolve-git-dir /Users/jenkins/workspace/epics-7.0/OS/mac/.git # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
 > git --version # timeout=10
 > git --version # 'git version 2.21.1 (Apple Git-122.3)'
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --force --progress -- https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/* # timeout=10
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/epics-base/
	at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1004)
	at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1245)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1305)
	at hudson.scm.SCM.checkout(SCM.java:505)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1213)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:639)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:511)
	at hudson.model.Run.execute(Run.java:1889)
	at hudson.matrix.MatrixRun.run(MatrixRun.java:153)
	at hudson.model.ResourceController.execute(ResourceController.java:100)
	at hudson.model.Executor.run(Executor.java:433)
Caused by: hudson.plugins.git.GitException: Command "git fetch --tags --force --progress -- https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*" returned status code 1:
stdout:
stderr: remote: Enumerating objects: 59, done.
remote: Counting objects:   1% (1/59)
remote: Counting objects:   3% (2/59)
remote: Counting objects:   5% (3/59)
remote: Counting objects:   6% (4/59)
remote: Counting objects:   8% (5/59)
remote: Counting objects:  10% (6/59)
remote: Counting objects:  11% (7/59)
remote: Counting objects:  13% (8/59)
remote: Counting objects:  15% (9/59)
remote: Counting objects:  16% (10/59)
remote: Counting objects:  18% (11/59)
remote: Counting objects:  20% (12/59)
remote: Counting objects:  22% (13/59)
remote: Counting objects:  23% (14/59)
remote: Counting objects:  25% (15/59)
remote: Counting objects:  27% (16/59)
remote: Counting objects:  28% (17/59)
remote: Counting objects:  30% (18/59)
remote: Counting objects:  32% (19/59)
remote: Counting objects:  33% (20/59)
remote: Counting objects:  35% (21/59)
remote: Counting objects:  37% (22/59)
remote: Counting objects:  38% (23/59)
remote: Counting objects:  40% (24/59)
remote: Counting objects:  42% (25/59)
remote: Counting objects:  44% (26/59)
remote: Counting objects:  45% (27/59)
remote: Counting objects:  47% (28/59)
remote: Counting objects:  49% (29/59)
remote: Counting objects:  50% (30/59)
remote: Counting objects:  52% (31/59)
remote: Counting objects:  54% (32/59)
remote: Counting objects:  55% (33/59)
remote: Counting objects:  57% (34/59)
remote: Counting objects:  59% (35/59)
remote: Counting objects:  61% (36/59)
remote: Counting objects:  62% (37/59)
remote: Counting objects:  64% (38/59)
remote: Counting objects:  66% (39/59)
remote: Counting objects:  67% (40/59)
remote: Counting objects:  69% (41/59)
remote: Counting objects:  71% (42/59)
remote: Counting objects:  72% (43/59)
remote: Counting objects:  74% (44/59)
remote: Counting objects:  76% (45/59)
remote: Counting objects:  77% (46/59)
remote: Counting objects:  79% (47/59)
remote: Counting objects:  81% (48/59)
remote: Counting objects:  83% (49/59)
remote: Counting objects:  84% (50/59)
remote: Counting objects:  86% (51/59)
remote: Counting objects:  88% (52/59)
remote: Counting objects:  89% (53/59)
remote: Counting objects:  91% (54/59)
remote: Counting objects:  93% (55/59)
remote: Counting objects:  94% (56/59)
remote: Counting objects:  96% (57/59)
remote: Counting objects:  98% (58/59)
remote: Counting objects: 100% (59/59)
remote: Counting objects: 100% (59/59), done.
remote: Compressing objects:   2% (1/36)
remote: Compressing objects:   5% (2/36)
remote: Compressing objects:   8% (3/36)
remote: Compressing objects:  11% (4/36)
remote: Compressing objects:  13% (5/36)
remote: Compressing objects:  16% (6/36)
remote: Compressing objects:  19% (7/36)
remote: Compressing objects:  22% (8/36)
remote: Compressing objects:  25% (9/36)
remote: Compressing objects:  27% (10/36)
remote: Compressing objects:  30% (11/36)
remote: Compressing objects:  33% (12/36)
remote: Compressing objects:  36% (13/36)
remote: Compressing objects:  38% (14/36)
remote: Compressing objects:  41% (15/36)
remote: Compressing objects:  44% (16/36)
remote: Compressing objects:  47% (17/36)
remote: Compressing objects:  50% (18/36)
remote: Compressing objects:  52% (19/36)
remote: Compressing objects:  55% (20/36)
remote: Compressing objects:  58% (21/36)
remote: Compressing objects:  61% (22/36)
remote: Compressing objects:  63% (23/36)
remote: Compressing objects:  66% (24/36)
remote: Compressing objects:  69% (25/36)
remote: Compressing objects:  72% (26/36)
remote: Compressing objects:  75% (27/36)
remote: Compressing objects:  77% (28/36)
remote: Compressing objects:  80% (29/36)
remote: Compressing objects:  83% (30/36)
remote: Compressing objects:  86% (31/36)
remote: Compressing objects:  88% (32/36)
remote: Compressing objects:  91% (33/36)
remote: Compressing objects:  94% (34/36)
remote: Compressing objects:  97% (35/36)
remote: Compressing objects: 100% (36/36)
remote: Compressing objects: 100% (36/36), done.
remote: Total 36 (delta 29), reused 0 (delta 0)
From https://git.launchpad.net/epics-base
   3d09106b5..66ff5a7bb  7.0        -> origin/7.0
Fetching submodule modules/pvAccess
From https://github.com/epics-base/pvAccessCPP
   7240f97..75e3d9e  master     -> origin/master
Could not access submodule '.ci'
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2681)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:2102)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:86)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:624)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:160)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:153)
	at hudson.remoting.UserRequest.perform(UserRequest.java:211)
	at hudson.remoting.UserRequest.perform(UserRequest.java:54)
	at hudson.remoting.Request$2.run(Request.java:376)
	at hudson.remoting.InterceptingExecutorService.lambda$wrap$0(InterceptingExecutorService.java:78)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
	at java.lang.Thread.run(Thread.java:748)
	Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to mac-1
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1795)
		at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:356)
		at hudson.remoting.Channel.call(Channel.java:1001)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:145)
		at sun.reflect.GeneratedMethodAccessor927.invoke(Unknown Source)
		at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
		at java.lang.reflect.Method.invoke(Method.java:498)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:131)
		at com.sun.proxy.$Proxy93.execute(Unknown Source)
		at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1002)
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.*/*.tap
Saving reports...
TAP Reports Processing: FINISH
Notifying upstream projects of job completion
Email was triggered for: Failure - Any
Sending email for trigger: Failure - Any
Sending email to: core-talk at aps.anl.gov
epics-7.0 » mac - Build # 363 - Fixed! APS Jenkins via Core-talk
Prev: RE: Building base 7.0.6 with parallel make fails on windows-x64 Mark Rivers via Core-talk
Next: epics-7.0 » linux32 - Build # 362 - Still Unstable! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Build completed: EPICS Base 7 base-7.0-388 AppVeyor via Core-talk
Next: epics-7.0 » mac - Build # 363 - Fixed! APS Jenkins via Core-talk
ANJ, 01 Oct 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
