2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1938459] Re: int64in only checks lower 32 bits for change
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 11 Oct 2021 18:13:42 -0000
** Changed in: epics-base
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1938459
Title:
Status in EPICS Base:
  Fix Released
Bug description:
  Create an int64in record and write these values
  (example uses bash to convert hex into decimal since caput cannot directly handle hex?):
  caput sixtyfour $(( 16#FF ))
  Old : sixtyfour                      0
  New : sixtyfour                      255
  caput sixtyfour $(( 16#87654321 ))
  Old : sixtyfour                      255
  New : sixtyfour                      2.27156e+09
  caput sixtyfour $(( 16#32187654321 ))
  Old : sixtyfour                      2.27156e+09
  New : sixtyfour                      3.44254e+12
  A camonitor will show 255, then 2.27156e+09, but not 3.44254e+12. A
  caget or a newly started camonitor will see the latest value.
  Reason is this section in int64inRecord.c:
  /* DELTA calculates the absolute difference between its arguments
   * expressed as an unsigned 32-bit integer */
  #define DELTA(last, val) \
      ((epicsUInt32) ((last) > (val) ? (last) - (val) : (val) - (last)))
  It only checks for changes in the lower 32 bits of the value.
  Maybe the motivation was to always perform an _unsigned_ comparison, but "UInt32" was copy/pasted instead of "UInt64"?
  One fix should be to replace epicsUInt32 with epicsUInt64 in DELTA and
  where it's used.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1938459/+subscriptions
[Bug 1938459] [NEW] int64in only checks lower 32 bits for change kasemir via Core-talk
Prev: [Bug 1941875] Re: Buggy warning message "Record/Alias name '...' should not contain non-printable ... Andrew Johnson via Core-talk
Next: [Bug 1702254] Re: add -fno-strict-aliasing for more architectures in R3.16 src/ca/legacy Makefiles Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1938459] Re: int64in only checks lower 32 bits for change Andrew Johnson via Core-talk
Next: Build failed in Jenkins: EPICS-7 #373 Jenkins EPICS PSI via Core-talk
ANJ, 11 Oct 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
