2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] CA gateway chaining
From: Timo Korhonen via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>
Date: Mon, 1 Nov 2021 15:35:45 +0000
Right, this is the way we are going for now. It is not exactly trivial to manage but should be doable.
TImo
From: Core-talk <core-talk-bounces at aps.anl.gov> on behalf of EPICS Core Talk <core-talk at aps.anl.gov>
Reply-To: Ralph Lange <ralph.lange at gmx.de>
Date: Monday, 1 November 2021 at 16:18
To: EPICS Core Talk <core-talk at aps.anl.gov>
On Wed, 27 Oct 2021 at 10:49, Timo Korhonen via Core-talk <core-talk at aps.anl.gov> wrote:
Just a short follow-up.
We found out that the delays are due to large arrays being monitored over the gateway. Not a surprise, even if we have tried to remind users about the effects with big arrays.
One way to mitigate this - I think this approach was implemented at some point at the SLS - is to route the large array channels through a dedicated separate gateway instance.
(Ease of configuration depends on your naming convention.)
Cheers,
~Ralph
RE: [EXTERNAL] CA gateway chaining Pearson, Matthew R. via Core-talk
Re: [EXTERNAL] CA gateway chaining Zimoch Dirk (PSI) via Core-talk
CA gateway chaining Timo Korhonen via Core-talk
Re: [EXTERNAL] CA gateway chaining Hartman, Steven via Core-talk
Re: [EXTERNAL] CA gateway chaining Timo Korhonen via Core-talk
Re: [EXTERNAL] CA gateway chaining Ralph Lange via Core-talk
Prev: Re: [EXTERNAL] CA gateway chaining Ralph Lange via Core-talk
Next: RE: [EXTERNAL] CA gateway chaining Pearson, Matthew R. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
ANJ, 02 Nov 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
