2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Strange UDP message on VxWorks 6.9
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Dirk Zimoch <dirk.zimoch at psi.ch>
Cc: EPICS core-talk <core-talk at aps.anl.gov>, Michael Davidsaver <mdavidsaver at gmail.com>
Date: Tue, 14 Dec 2021 15:54:03 +0000
Agreed, Dirk please apply the Wind River patches if possible — that will make you more up to date than we are currently at APS (6.9.4.1 as Mark said) but I will probably be upgrading for our APS Upgrade early next year. However you should be aware that they broke their ABI somewhere between 6.9 and 6.9.4.1 in the code that queries network interfaces, so you will have to recompile Base at least after doing that (not sure about Asyn or other modules that use the network APIs).
Is it worth adding a check to libcom/test/epicsTypesTest.c to detect this issue? I would only be in favor of that if the test does not add compiler warnings to every other architecture, although a build warning (or even a build error) from broken targets would be fine. It would only make sense to check this for the int8_t though which happens due to the ambiguous signedness of a bare char.
- Andrew
On Dec 14, 2021, at 9:20 AM, Zimoch Dirk (PSI) via Core-talk <core-talk at aps.anl.gov> wrote:
Thanks Mark.
It seems I should update my vxWorks 6.9.
Dirk
Von: Mark Rivers <rivers at cars.uchicago.edu>
Gesendet: Dienstag, 14. Dezember 2021 16:10
An: Michael Davidsaver <mdavidsaver at gmail.com>; Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
Cc: 'core-talk at aps.anl.gov' <core-talk at aps.anl.gov>
Betreff: Re: Strange UDP message on VxWorks 6.9
Hi Dirk,
At the APS we are running vxWorks 6.9.4.1.
A grep for int8_t in this file
/usr/local/vw/vxWorks-6.9.4/vxworks-6.9.4/target/h/stdint.h
shows:
corvette:vxworks-6.9.4/target/h>grep int8_t stdint.h
01c,30jul12,cww  explicitly declare int8_t as signed (WIND00365953)
typedef signed char int8_t;
typedef unsigned char uint8_t;
So it looks like that was changed to add "signed" on July 30, 2012.
From: Core-talk <core-talk-bounces at aps.anl.gov> on behalf of Zimoch Dirk (PSI) via Core-talk <core-talk at aps.anl.gov>
Sent: Tuesday, December 14, 2021 8:30 AM
To: Michael Davidsaver <mdavidsaver at gmail.com>
Subject: AW: Strange UDP message on VxWorks 6.9
Hi Michael,
After putting a lot of debug messages into the code, I found the big difference between vxWorks 6.9.0 on ppc604 and all the other architectures:  signedness of int8 aka char!
As a result, FieldCreate::deserialize takes a different path with the same input (beacon):
    int8 code = buffer->getByte();
On vxWorks 6.7 and Linux, code is -1, but on vxWorks 6.9, code is 255.
Thus, the next line does not work as expected
    if (code == -1)
        return FieldConstPtr();
Instead, an array field is assumed but there is not enough data for that.
The type definitions come from here:
include/pv/pvType.h:typedef int8_t   int8;
$WINDBASE/vxworks-6.9/target/h/stdint.h:typedef char int8_t;
Thus, if char is unsigned, then int8_t is unsigned too and as a consequence int8 as well. This is obviously a bug in vxWorks, as the stdint.h man page says:
"The  typedef  name  int  N _t designates a signed integer type with width N, no padding bits, and a two's-complement representation. Thus, int8_t denotes a  signed integer type with a width of exactly 8 bits."
WindRiver should better have used 'typedef signed char int8_t;' as they had in vxWorks 6.7! (As well as any Linux implementation I checked.)
Can someone please check if they have fixed this in higher vxWorks 6.9 releases?
I have added the compiler flag -fsigned-char to ARCH_DEP_CFLAGS for vxWorks 6.9 and that fixes the problem.
Dirk
> -----Ursprüngliche Nachricht-----
> Von: Core-talk <core-talk-bounces at aps.anl.gov> Im Auftrag von Zimoch Dirk
> (PSI) via Core-talk
> Gesendet: Montag, 22. November 2021 15:35
> Betreff: AW: Strange UDP message on VxWorks 6.9
> Repeating the tests, I found some that fail on vxWorks.
>  I think I collect them in a bug tracker issue...
> > Von: Zimoch Dirk (PSI)
> > Gesendet: Freitag, 19. November 2021 15:05
> > An: 'Michael Davidsaver' <mdavidsaver at gmail.com>
> > I cross-checked with printf and found that the 47 is indeed hex!
> > I also found that the FIRST message is:
> > Error on UDP RX 172.20.4.26:57620 -> 172.20.255.255:5076 at 71 : no more
> > data in UDP packet : 71:71 for 1
> > But all the next messages are:
> > Error on UDP RX 172.20.2.154:49166 -> 172.20.255.255:5076 at 47 : no more
> > The reason is HexDump operator << which switches the output stream to hex
> > and leaves it like that.
> > I have run tests for libCom, pvData and pvAccess and they succeed.
> > BTW: Some other tests harnesses require dbd files like linkTest.dbd that do not
> > get installed (even though the *Harness.munch files are installed).
> > > Gesendet: Freitag, 19. November 2021 09:56
> > > > Von: Michael Davidsaver <mdavidsaver at gmail.com>
> > > > Gesendet: Donnerstag, 18. November 2021 17:30
> > > > An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
> > > > Dirk,
> > > > Have you run the unit tests for Base, pvDataCPP, and pvAccessCPP?
> > > Not on vxWorks.
> > > > On 11/18/21 6:08 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> > > > > Hi everybody
> > > > > For a while, I have EPICS 7.0.6.1 running on some vxWorks 6.7 IOCs. Now
> I
> > > > upgraded one of them to vxWorks 6.9 and get those strange errors:
> > > > > Error on UDP RX 172.20.4.25:48599 -> 172.20.255.255:5076 at 47 : no
> > more
> > > > > 0x00 ca024000 27000000 73599561 00000000  ..@. '... sY.a ....
> > > > > 0x10 68ab0e1c 00680000 00000000 00000000  h... .h.. .... ....
> > > > > 0x20 0000ffff 00000000 3edd0374 6370ff    .... .... >..t cp.
> > > > > I found the messages to pvAccess/src/remote/blockingUDPTransport.c,
> > but
> > > it
> > > > is hard to understand what it means or why it appears on vxWorks 6.9 but
> > not
> > > > vxWorks 6.7.
> > > > I can't explain this.
> > > > This looks like a valid CMD_BEACON packet (see below), which is also
> > implied
> > > by
> > > > silence from other PVA peers which presumably see this broadcast.
> > > > In particular, I don't see how "71" appears.  The message length is 47 bytes
> > > > (0x27 body + 8 header).  The fact that 0x47 == 71 is suggestive, but I don't
> > > > see where this confusion could be sneaking in.
> > > > It also isn't clear to me if this is simply when printing the message, or when
> > > > interpreting the packet.
> > > > The order of formatting is such that "no more data in UDP packet : 71:71
> for
> > > 1"
> > > > is constructed first using a temporary std::ostringstream.  So I have
> > confidence
> > > > that this stream _should_ be set to base 10.
> > > > The rest of the message is formatted using std::cerr, so it is possible that
> the
> > > > "47" is base 16.
> > > I can check that by using printf. Just to be sure.
> > > I find it difficult to debug because I do not know which function has originally
> > > called the function that throws the exception. Maybe I abort() rather than
> > throw
> > > and have a look at the call stack.
> > > > I'm afraid I don't have any suggestion beyond ensuring that there isn't any
> > > > mixing
> > > > of object code compiled for vx6.7 vs 6.9.
> > > There isn't. Otherwise this would most probably not be the only problem.
> > > > > It may be that I configured something wrong on vxWorks 6.9 as I had to
> > > > migrate the BSP for the no longer supported architecture from 6.7 to 6.9
> and
> > > > had difficulties to get networking running initially.
> > > > > But networking works now and neither CA nor PVA nor NFS show any
> > > > problems.
> > > > > Any ideas? [Looking in Michael's direction]
> > > > > Dirk
> > > > version=2 CMD_BEACON LSB length=0x27 (39 bytes)
> > > > total message length including header is 47 bytes
> > > > https://github.com/epics-base/pvAccessCPP/wiki/Protocol-
> > > Messages#message-
> > > > header
> > > > Messages#cmd_beacon-0x00
> > > > >    73599561 00000000
> > > > > 0x10 68ab0e1c
> > > > GUID 0x735995610000000068ab0e1c
> > > > This is consistent w/ pvAccessCPP/Java which use system boot time
> > > > as a "unique" ID...
> > > > 0x61955973 -> Wed Nov 17 11:35:15 2021 PST
> > > > >    00680000
> > > > flags=0 beaconSequenceId=0x68 changeCount=0
> > > > >    00000000 00000000
> > > > server adddress is ::ffff:0.0.0.0
> > > > which is expected
> > > > >  3edd
> > > > port=56638
> > > > >  0374 6370
> > > > 3 byte string "tcp"
> > > > >  ff
> > > > PVD NULL, which again is allowed
Complexity comes for free, simplicity you have to work for.
AW: Strange UDP message on VxWorks 6.9 Zimoch Dirk (PSI) via Core-talk
Re: Strange UDP message on VxWorks 6.9 Michael Davidsaver via Core-talk
Re: Strange UDP message on VxWorks 6.9 Mark Rivers via Core-talk
Prev: AW: Strange UDP message on VxWorks 6.9 Zimoch Dirk (PSI) via Core-talk
Next: AW: Strange UDP message on VxWorks 6.9 Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
ANJ, 14 Dec 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
