This is not a pvAccess issue…The alarm status and severity is set by the record, right?
I just used pvget to check the status of the record; caget tells exactly the same thing.
The description in the NT specification is there for reference and not a specification for the implementation, would be in a totally wrong place there. Right?
There is one issue in VTypes as well but the IOC behavior does seem to have an issue on its own that has to be solved, or explained if I (and Kay) have understood it wrong.
Timo
Core-talk <core-talk-bounces at aps.anl.gov> on behalf of EPICS Core Talk <core-talk at aps.anl.gov>
Reply to: Ralph Lange <ralph.lange at gmx.de>
Date: Tuesday, 8 March 2022 at 16:51
To: EPICS Core Talk <core-talk at aps.anl.gov>
Subject: Re: Definition (or not) of alarm limits
Hi all,
We noticed recently that if for instance the lower alarm limits are not explicitly defined in the EPICS database, CS-Studio reports all limits to be NaN. See here
https://github.com/ControlSystemStudio/cs-studio/issues/2716 for a description and a following discussion.
Kay pointed out that even when the limits are explicitly defined as 0, the IOC reports them as NaN. Now this starts to smell like a bug. But before I submit a bug report, I wanted to ask if there is a reason behind this behavior? Maybe it
is a feature and not a bug?
There is another interesting case, described by Kay in the above issue report, when only one HIGH and not HIHI is defined. How should this case be interpreted? The “Process Database Concepts” documentation (
https://docs.epics-controls.org/en/latest/guides/EPICS_Process_Database_Concepts.html#alarm-conditions-configured-in-the-database ) indicates that the alarm limits express a range, however not very explicitly. But this is not consistent with this case.
Any thoughts?
Isn't that part of the Normative Types spec the definition of alarm limits in pvAccess?
This range thing seems to be a 'VType' problem.
- Re: Definition (or not) of alarm limits Andrew Johnson via Core-talk
- Definition (or not) of alarm limits Timo Korhonen via Core-talk
- Re: Definition (or not) of alarm limits Ralph Lange via Core-talk
<2022>
2025
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
