Bull's eye
I could have thought of it myself ;-(
more ./rtems/6/powerpc-rtems6/beatnik/lib/include/link.h
#ifndef _LINK_H_
#define _LINK_H_
* Pull in the correct definitions for our toolchain target.
#ifdef __ELF__
#include <link_elf.h>
#else
#include <link_aout.h>
#endif
#endif /* _LINK_H_ */
Danke! Heinz
> On 12. Mar 2022, at 18:23, Michael Davidsaver <mdavidsaver at gmail.com> wrote:
> On 3/12/22 09:13, Heinz Junkes via Core-talk wrote:
>> When compiling epics-base with rtems6 I get the error " unknown type name 'DBLINK' “.
>> in link.h (wird von dbAccess.h included) findet man dies:
>> struct link {
>> struct dbCommon *precord; /* Pointer to record owning link */
>> short type;
>> short flags;
>> struct lset *lset;
>> char *text; /* Raw link text */
>> union value value;
>> typedef struct link DBLINK;
>> Does anyone have an idea what is going wrong here? Can this be due to gcc-10 (powerpc-rtems6-gcc (GCC) 10.3.1) ?
> I've been successfully using GCC 10.2 for some time, and GCC developers are usually strict
> about not making potentially breaking changes in a minor release.
> I'd suggest approaching this by looking at the output of the preprocessor to make sure the
> typedef DBLINK from link.h is really being included. Maybe there is another link.h ?
> The straightforward, but ugly, way to do this is to copy+paste the failing gcc invocation
> and replace '-c' with '-o .../some.c -E'. Running this from the appropriate
> O.* directory.
>> Heinz
>> /home/rtems/MVME6100_WORK/rtems/6/bin/powerpc-rtems6-gcc -fasm -I/home/rtems/MVME6100_WORK/rtems/6/powerpc-rtems6/beatnik/lib/include -mcpu=7400 -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUNIX -O2 -g -fdata-sections -ffunction-sections -Wall -Werror-implicit-function-declaration -DRTEMS_HAS_ALTIVEC -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120 -mcpu=7400 -I/home/rtems/MVME6100_WORK/rtems/6/powerpc-rtems6/beatnik/lib/include -D__LINUX_ERRNO_EXTENSIONS__ -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include -MM -MF asDbLib.d ../as/asDbLib.c
>> perl -CSD /home/rtems/EPICS_TST/epics-base/bin/linux-x86_64/genVersionHeader.pl -t ../../../../.. -N EPICS_VCS_VERSION -V "" ../O.Common/epicsVCS.h
>> Keeping VCS header ../O.Common/epicsVCS.h
>> EPICS_VCS_VERSION = "R7.0.6.1-75-g91941af992f6c32ef4f4-dirty"
>> Expanding ../databaseVersion.h@ to ../O.Common/databaseVersion.h
>> perl -CSD /home/rtems/EPICS_TST/epics-base/bin/linux-x86_64/expandVars.pl -t ../../../../.. -DEPICS_DATABASE_MAJOR_VERSION="3" -DEPICS_DATABASE_MINOR_VERSION="21" -DEPICS_DATABASE_MAINTENANCE_VERSION="1" -DEPICS_DATABASE_DEVELOPMENT_FLAG="1" ../databaseVersion.h@ databaseVersion.h
>> Installing generated generic include file ../../../../../include/databaseVersion.h
>> /home/rtems/MVME6100_WORK/rtems/6/bin/powerpc-rtems6-gcc -fasm -I/home/rtems/MVME6100_WORK/rtems/6/powerpc-rtems6/beatnik/lib/include -mcpu=7400 -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUNIX -O2 -g -fdata-sections -ffunction-sections -Wall -Werror-implicit-function-declaration -DRTEMS_HAS_ALTIVEC -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120 -mcpu=7400 -I/home/rtems/MVME6100_WORK/rtems/6/powerpc-rtems6/beatnik/lib/include -D__LINUX_ERRNO_EXTENSIONS__ -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include -c ../as/asDbLib.c
>> In file included from ../db/dbAccess.h:27,
>> from ../as/asDbLib.c:31:
>> ../O.Common/dbCommon.h:27:5: error: unknown type name 'DBLINK'
>> 27 | DBLINK tsel; /**< @brief Time Stamp Link */
>> ../O.Common/dbCommon.h:31:5: error: unknown type name 'DBLINK'
>> 31 | DBLINK sdis; /**< @brief Scanning Disable */
>> ../O.Common/dbCommon.h:66:5: error: unknown type name 'DBLINK'
>> 66 | DBLINK flnk; /**< @brief Forward Process Link */
>> make[5]: *** [../../../../../configure/RULES_BUILD:259: asDbLib.o] Error 1
>> make[5]: Leaving directory '/home/rtems/EPICS_TST/epics-base/modules/database/src/ioc/O.RTEMS-beatnik'
>> make[4]: *** [../../../../configure/RULES_ARCHS:58: install.RTEMS-beatnik] Error 2
>> make[4]: Leaving directory '/home/rtems/EPICS_TST/epics-base/modules/database/src/ioc'
>> make[3]: *** [../../../configure/RULES_DIRS:85: ioc.install] Error 2
>> make[3]: Leaving directory '/home/rtems/EPICS_TST/epics-base/modules/database/src'
>> make[2]: *** [../../configure/RULES_DIRS:85: src.install] Error 2
>> make[2]: Leaving directory '/home/rtems/EPICS_TST/epics-base/modules/database'
>> make[1]: *** [../configure/RULES_DIRS:85: database.install] Error 2
>> make[1]: Leaving directory '/home/rtems/EPICS_TST/epics-base/modules'
>> make: *** [configure/RULES_DIRS:85: modules.install] Error 2
- Re: unknown type name 'DBLINK' Michael Davidsaver via Core-talk
- unknown type name 'DBLINK' Heinz Junkes via Core-talk
Build failed: EPICS Base 7 base-7.0-483 AppVeyor via Core-talk
<2022>
2025
<2022>
2025
