2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Question PVA environment variable
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Kim, Kukhee" <khkim at slac.stanford.edu>
Cc: EPICS core-talk <core-talk at aps.anl.gov>, "Zelazny, Michael Stanley" <zelazny at slac.stanford.edu>
Date: Tue, 15 Nov 2022 11:11:15 -0800
I realize I forgot to CC the core-talk list.
On 11/9/22 06:51, Michael Davidsaver wrote:
On 11/8/22 22:37, Kim, Kukhee wrote:
Hi  Michael,
Thank you so much for your advice.
The multicast address is:  224.0.0.128
Ah, right...  This address is used by PVA instead of something like caRepeater.
It should only be sent via the loopback interface through.
You can run "ip maddr" to see that 224.0.0.128 appears for the "lo" interface,
but not for any others.
$ ip maddr
1:      lo
        inet  224.0.0.128 users 2
        inet  224.0.0.1
        inet6 ff02::1
        inet6 ff01::1
Are you seeing packets with this destination address actually going out on a wire?
We have PVA address setup as the followings:
EPICS_PVA_ADDR_LIST='<broadcast addr for subnet>  255.255.255.255'
EPICS_PVA_AUTO_ADDR_LIST=NO
EPICS_PVA_BROADCAST_PORT=5076
EPICS_PVA_SERVER_PORT=507
Hi Ernest and Mike,
Can we capture the packet which goes to the multicast address to recognize searching or beacon?
Thank you for your help.  I will update you.
Thank you.
Best regards,
Kukhee
*From:* Michael Davidsaver <mdavidsaver at gmail.com>
*Sent:* Tuesday, November 8, 2022 9:14 PM
*To:* Kim, Kukhee <khkim at slac.stanford.edu>
*Cc:* Zelazny, Michael Stanley <zelazny at slac.stanford.edu>; core-talk at aps.anl.gov <core-talk at aps.anl.gov>
*Subject:* Re: Question PVA environment variable
On 11/8/22 13:00, Kim, Kukhee via Core-talk wrote:
Hi Everyone,
We just realized that some of our servers send out packets to port 5076 in multicasting address.
What multicast address(es) are you seeing?
Can you look (with packet capture) to see if these are
search or beacon messages?
Since, the multicasting address is used for some of specific services, we would like to prevent the PVA, PVXS traffic to the multicasting address.
PVXS should not send any multicast traffic by default.
(we have no assigned addresses to use for PVA)
Is there any PVA environment variables to control it?
https://mdavidsaver.github.io/pvxs/netconfig.html <https://mdavidsaver.github.io/pvxs/netconfig.html>
There are a couple, all of the form EPICS_PVA*_ADDR_LIST
Thank you so much for your help and support!
Best regards,
Kukhee
Kukhee Kim | *Engineering Physicist *
Advanced Controls Department
SLAC National Accelerator Laboratory | Menlo Park, CA
p: 650.926.4912 | m: 669.300.8192 | email: khkim at slac.stanford.edu
Re: Question PVA environment variable Williams Jr., Ernest L. via Core-talk
Question PVA environment variable Kim, Kukhee via Core-talk
Re: Question PVA environment variable Michael Davidsaver via Core-talk
Prev: epics-7.0 » mac - Build # 436 - Failure! APS Jenkins via Core-talk
Next: epics-7.0 » mac - Build # 437 - Still Failing! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: Question PVA environment variable Michael Davidsaver via Core-talk
Next: Re: Question PVA environment variable Williams Jr., Ernest L. via Core-talk
ANJ, 16 Nov 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
