2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: OPI updates when enum strings/values change
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Tue, 2 May 2023 11:17:17 -0700
On 5/2/23 10:31, Mark Rivers wrote:
Hi Michael,
Thanks for the quick reply!
Indeed changing the Phoebus settings.ini to have this line gives the correct behavior:
org.phoebus.pv.ca/dbe_property_supported=true
fyi. The reason this isn't the default actually has less to do with support in Base,
and more to do with ca-gateway not reacting well to unknown DBE_* bits.  DBE_PROPERTY
was not fully supported until ca-gateway 2.1.0 (circa 2016).
OPI updates when enum strings/values change Mark Rivers via Core-talk
Re: OPI updates when enum strings/values change Michael Davidsaver via Core-talk
RE: OPI updates when enum strings/values change Mark Rivers via Core-talk
Prev: Re: OPI updates when enum strings/values change Andrew Johnson via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-918 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: RE: OPI updates when enum strings/values change Mark Rivers via Core-talk
Next: Re: OPI updates when enum strings/values change Andrew Johnson via Core-talk
ANJ, 03 May 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
