Background: To ease the tight policy of AppVeyor a bit - and keep multi-day backlogs from happening too often - we were creating multiple accounts on AppVeyor and split the CI jobs between them by branch / project: epics-base Base (7.0, manual, using .appveyor.yml), pvAccess, pvData, ci-scripts (only tags, no PRs), pva2pva epics-modules ci-scripts, gtest, pcas epics-base-7 Base (branch 7.0, using .appveyor/epics-base-7.yml) epics-base-3 Base (branch 3.15, using .appveyor/epics-base-3.yml) So, the top level .appveyor.yml could probably be removed if the manual epics-base build points to the same configuration as the epics-base-7 build. New builds for the automated 7.0 branch CI should go to .appveyor/epics-base-7.yml Cheers, ~Ralph
ANJ, 23 May 2023 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
